Old 15th May 2004, 12:32 AM   #1
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Default 2 pairs of DIY Dipoles
Here are my latest 2 pairs of dipoles. The arrays use cheap drivers with Shiva's boxed in the bottom. The 2nd pair is Adire HE8.1's on top using the Adire Xover and 4 6" TV drivers in a push pull W baffle in the bottom with a 1st order roll-off at 100hz. I used a very heavy hard wood called Cenizaro and the beautiful grain will really stand out once a add the finish. They are truely one of a kind, since it is now illegal to cut these trees.
I've found that the space saving swept back wings and polyfill stuffing in the back make placement close to the back wall work quite well.
I'm in the process of making similar, but more compact dipoles for my surrounds and center channel.
Everyone has a photographic memory. It's just that most are out of film.
Old 15th May 2004, 12:35 AM   #2
And the HE8.1 Dipoles
Old 15th May 2004, 02:27 AM   #3
These look really good. Could you post some pictures of the back? I'd like to see what you did with the polyfill.
Old 15th May 2004, 03:25 AM   #4
Here are the backs. The arrays have a thin layer of polyfill behind the drivers covered with a 1/2" layer of foam rubber. I did some experimenting with the HE8.1's and the back will have a thin layer of foam rubber on the wings and top. Then around the back of the top driver I'll put polyfill held in place with a thin stretchy material which will also hide the crossover components. I found that this makes placement much less crutial. With no damping at some back wall distances I was getting some cavity sounds. With very close proximity to the back wall, I find a small loss of soundstage depth.
It's hard to tell from the pictures, but it is very important that the baffle "wings" are of different lengths. I could hear only a little difference having the short wings on the outside or inside, so I've decided to keep the long wings on the outside which hides the guts of the speaker better.
Old 15th May 2004, 05:17 AM   #5
Thanks, that gives me some ideas for my own project.
Dipoles ? LennyK Multi-Way 111 21st September 2006 03:12 PM
FE166E in dipoles xstephanx Full Range 2 14th June 2006 05:55 PM
Vas, cms, etc... for Dipoles Raka Multi-Way 21 19th February 2006 05:43 AM
3-way or 4-way dipoles? mazeroth Multi-Way 0 25th January 2006 06:37 AM
SPL max and dipoles XLS Raka Multi-Way 11 21st July 2004 08:34 PM
Page generated in 0.07530 seconds (83.45% PHP - 16.55% MySQL) with 11 queries
