2.5-way or 2-way w/sub? - diyAudio
Old 15th May 2004, 12:30 AM   #1
dmitriy167's Avatar
Default 2.5-way or 2-way w/sub?
I have a pair of Peerless 6.5" CSX (850122) woofers, and I was wondering if it is better to buy another pair (and have a pair of drivers per speaker in a 2.5way arrangement) or stick to a 2-way with a sub (10"CSX maybe). In both cases, I would use sealed boxes for both the mains and the sub because I like the tighter bass and I can never get the port tuning right. So what would be better for bass extension?
Old 15th May 2004, 12:56 AM   #2
Bill Fitzpatrick's Avatar
How about 2.5 way AND 2 12" subs?
Old 15th May 2004, 01:53 AM   #3
dmitriy167's Avatar
That might be an idea (if I had the money for this kind of setup). But the 6.5" Peerless woofers have some fairly clean bass on their own, but they drop rapidly below 45Hz in my (2-way ported) setup. My goal is to extend the lows of the system down to about 35Hz with the 2.5way or 25 Hz with the sub (or subs). I think 2 12" subs would be a bit too much for my room, and they would take up a heck of a lot of space (like 130L or so) if they were to go to 25Hz in a closed box. Again, I don't have THAT much money to spend; I can always add a second (same) sub later.
Old 15th May 2004, 03:19 AM   #4
You could get the second pair of 6.5s and mount the second pair in the back in a push-push bipole setup, to take care of baffle step and extend the bass. If it were me I'd tend to go this way also because it's a modular, extensible setup; you can always add a sub later for the bottom octave if you find you want it.
I understand this method is favored by Planet10, there's some info on his web site here.
Old 15th May 2004, 04:43 AM   #5
dmitriy167:
How are you going to handle the amplification and crossovers?
Old 15th May 2004, 05:16 AM   #6
frugal-phile(tm)
planet10's Avatar
Who woulda guessed this would be the way i'd go
Keep in mind that a 2nd driver the same won't take you any lower, just give you more.... which with a 6.5 & 45 Hz is almost required.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th May 2004, 09:20 AM   #7
diyAudio Member RIP
A small sealed box with an added subwoofer is your best bet.
A 2.5 way will give more volume and efficiency but not more bass,
not unless you build a 50 litre reflex tuned to around 36Hz.
http://www.speakerbuilder.net/web_fi...k/pcrkmain.htm
A sealed version with 0.5cuft / 14L stuffed will be fine, Q ~ 0.7.
For your subwoofer, unless the driver is specifically designed
for sealed boxed loading an overdamped reflex is better.
sreten.
Old 15th May 2004, 01:50 PM   #8
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
This is what I did with mine using the 850122's. Very effective, and mainly used it for BSC. More bottom end now but does not go any lower. Has a perception of going lower but I think it's only the increase in SPL due to BSC.
Old 15th May 2004, 04:16 PM   #9
dmitriy167's Avatar
sreten.
I am building a pair of ~50L boxes now, and this is an option. But I don't like the idea of a port too much. I like my bass tight.
I should have thought of this from the start. I might be able to mount the drivers in a bipole config in the 50L sealed boxes. The question then is if I should make the back drivers take care of the bass only, or if they could run into the midrange like the front drivers.
Old 15th May 2004, 04:47 PM   #10
rabbitz's Avatar
I use mine only for BSC and roll off from 575Hz using a 1st order crossover. BTW, mine are used in a vented box. If you are building a 50 litre box you could always try sreten's suggestion of trying a vented box tuned to 36Hz. If you don't like it you can then go sealed....... or build 1 of each and compare. Just a thought.
Cheers
Copyright 1999-2017 diyAudio
