Experienced builders:
For the midrange, which is better: the best 5" in a box (sealed/aperiodic/vented) or the best 6.5" open-baffled? I've heard that >6" drivers do not have the clarity in the midrange that the best 5" drivers do. However, they have lower distortion in the lower frequencies and are more suitable for open-baffle designs, which AFAIK improves midrange clarity.
KTK. Kool To the Kore. |
#2 |
What is wrong with 5" in an OB? My seas excel go plenty loud enough for the neighbours to complain in an OB.
If max SPL is your game then a box is better, if sound is then OB is. Also note that Linkwitz uses 8" in his designs and they are reputed to be some of the best. What drivers did you have in mind?
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#3 |
6.5" OB. The dipole aspect easily makes up for any psychosomatic "clarity" issue.
http://seas.no/excel_line/excel/E0021.PDF http://seas.no/excel_line/excel/E0022.pdf Compare the distortion graphs and tell me if one is clearly better than the other. In fact, in the region of 300Hz to 1kHz, it looks like the 8" driver is cleaner than the 5" one. |
#4 |
Yes apparently the 8" is cleaner then the others thats another reason why linkwitz chosethe 8"
I guess he got the best of both worlds, lowest dist and 8" for lower cone movement.
#5 | |
Not the SEAS Excel due to resonance peaks. Maybe more modest drivers like Vifa Classic/Peerless HDS?
#6 |
If sound and max. SPL is your game then perhaps you could look at a Line array Open Baffle.
ERTW 4 life! "the day has 24hours. If that is not enough take the night."-Roemhild |
#7 | |
| "Box" design and bracing for open baffle woofer array | ryoshu | Multi-Way | 0 | 17th August 2008 06:07 PM |
| "The J'OB.". baffled... | Andy G | Multi-Way | 5 | 29th December 2007 06:49 AM |
| MIT Open Courseware "Circuits and Electronics" (25 Lecture videos) | KP11520 | Everything Else | 1 | 2nd August 2007 09:39 PM |
| design help needed: monopole 15" / 8" MTM open baffle with Manger | taloyd | Multi-Way | 26 | 26th January 2007 10:53 PM |
| FS: 8.4" and 12.1" Open Frame LCD [Michigan] (Warning: Large Pictures) | ry.david | Swap Meet | 0 | 8th July 2006 12:14 AM |
| Page generated in 0.10543 seconds (68.75% PHP - 31.25% MySQL) with 10 queries |
