1) What are the advantages of a coaxial speaker design?
2) Is it just that a coaxial takes up less space and the sound output is on the same axis? 3) Or can they sound warmer, rounder, more present and smoother in the near field than a horn loaded speaker? 4) Are coaxial designs as capable of handling greater power and higher volumes as horn loaded speakers? coaxial cone driver:
#2 |
Simply put consistency of off axis response and none of
the things that you mention. Used to its best advantage with large bass drivers and a tweeter, where co-incident mounting does have major advantages. |
#3 |
My sole experience with coaxial speakers were the Tannoy Super Red Monitors. They were great with everything except one that I did not like was: in order to have good bass from them you'd have to set the volumn high, but by then the treble became too high of a volumn for my liking. May be there is a way to pad down the treble I do not know.
Just my 2 cents Chris |
#4 |
The advantage is a consistent dispersion pattern that helps in perfecting stereo imaging. I own a pair of Tannoy 8” Saturns but my Von Schweikert VR1’s sound way better IMHO despite they are no concentrics. Here is a tech paper from Tannoy: http://www.cortex.westhost.com/tanno...s/dualconc.pdf Cheers
#5 |
Coaxes are point sources, all the sound comes from the same center. This is a good thing along with the voice coils are usually in the same plane.
If it sounds good... it is good! |
#6 |
How about a coax in an OB?
| Poor sound from KEF coaxial speaker | Javachip | Multi-Way | 7 | 6th May 2009 06:29 AM |
| crossover for coaxial speaker | jrazor | Multi-Way | 3 | 8th May 2008 12:26 PM |
| Amp for Coaxial speaker with active crossover | partyjups | Chip Amps | 3 | 11th May 2006 10:51 AM |
| Coincident/coaxial design | MarkMcK | Multi-Way | 10 | 4th March 2005 07:16 PM |
| TB coaxial in HT or stereo speaker | MPM | Multi-Way | 0 | 20th December 2004 01:38 PM |
| Page generated in 0.06741 seconds (83.57% PHP - 16.43% MySQL) with 10 queries |
