Old 14th May 2004, 12:04 AM   #1
Send a message via AIM to eRiCdWoNg
Default Thoughts on this Tang-Bang 6.5" "sub"
http://www.partsexpress.com/pe/pshow...number=264-832
Looks interesting, got a huge xmax for such a little driver. I wonder if 2 of these in a hornloaded enclosure how that would do. anybody try these?
Old 14th May 2004, 12:06 AM   #2
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
The 8" version has more Xmax, and way larger motor, and more Sd, since its an 8" sub. Also, its cheaper by 10$.
Old 14th May 2004, 12:19 AM   #3
You dont happen to have its model # do you? I found this at their website... http://www.tb-speaker.com/detail/1208_03/w8-740c.asp
Old 14th May 2004, 12:33 AM   #4
go to www.tb-speaker.com, then go to contact, then dealers. Neura Acoustic has them for 32 each.
Old 14th May 2004, 01:14 AM   #5
herm is offline herm  United States
http://www.creativesound.ca/details.php?model=W8740C
Old 14th May 2004, 06:15 AM   #6
How do you all think this driver compares to the silverflute http://www.madisound.com/silverflute.pdf
W20RC38-04 at the very bottom left of that page.?
I'm also thinking of using it as a car stereo midbass. The TB has good excursion but only 84 db sensitivity. While the SF has 93. Of course I have no clue how that is measured or at what frequency but it seems like its a significant difference. Maybe i'll just buy both sets and try.
Old 15th May 2004, 05:50 AM   #7
go with the flute.
Old 15th May 2004, 01:50 PM   #8
Timn8ter's Avatar
I built a small sub for a friend using two of the TB W8s in a 45 liter enclosure. He's quite pleased with the results. Also, the latest issue of Audio Express has details of some "apartment subs" utilizing different brands of 8" woofers and the TB setup had the better results.
Old 11th March 2005, 08:57 PM   #9
DIAR is offline DIAR  Finland
DIAR's Avatar
I simulated two W8-740C in >30 L bass reflex enclosure tuned to 14 Hz. Reaches ~15 Hz 95 dB SPL. With a proper low pass filter it reaches 15 Hz -6dB and 18 Hz -3 dB.
Old 11th March 2005, 10:31 PM   #10
I built using the W8-740C, and in ~1cuft with porting, it makes lots of boom-like noises.
I used a homemade mono paralleled LM4780 gainclone and a cheap Radio Shack transformer to power it, too.
I think it cost me about $70 or $80 CDN after everything to build, and the results are pretty darned awesome. People who hear the system (has W3-871S-based LCR speakers teamed up with it) are shocked at how small everything is, and yet how (nicely) noisy it can get.
So, yeah. Buy the W8-740C -- wicked-good bang for your buck.
Chris
http://www.SuperMegaUltraGroovy.com
Finally! Acoustic Measurement software for Mac OS X -- http://www.fuzzmeasure.com
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Initial Thoughts for "Mr. Piggy" SE Amp w/Screen Driven 6P45S wrenchone Tubes / Valves 9 4th January 2009 10:39 AM
A 2 way using the Tang Bang 4" bamboo driver? saabracer23 Multi-Way 25 6th March 2007 04:18 AM
looking for the most "bang for buck" classD kit demogorgon Class D 4 23rd March 2006 06:57 PM
PC wireless mouse goes "bang" still works Rixsta Everything Else 2 20th May 2004 09:15 AM
Page generated in 0.10721 seconds (76.94% PHP - 23.06% MySQL) with 11 queries
