i almost finished my diy floorstander; it is described more in detail on my website http://www.krishu.de > hifi > speakers The speaker is based on a kit offered by http://www.dynamik-akustik.de It uses Eton ER4 Air Motion Transformers and two 7" Eton woofers. Crossover is tuned to about 2kHz, each woofer has about 16 liters volume and the reflex ports are tuned to about 40 Hz. He woodwork consists of 22mm thick MDF, the front is 44mm; everything is veneered with european cherry tree and waxed. Sensitivy is about 95 dB; Size is about 1.10m high and just more than 20 cm wide. The crossover sits in a separate chamber which was planned to be filled with sand but the speakers are so heavy now I will probably not do this. Any comments and suggestions are welcome. Cheers Christian
Visit my DIY page at www.krishu.de |
#2 |
Those look great!
I like the way you visually integrated the drivers with the black strip. The angled corners are nice and the finish is beautiful. What was the wax you used? I really like the subdued finish you get with wax. Nice site too. |
#3 |
since I am a student of industrial design I learned how to make things look better than they are ![]() I used "Antique Wax Oil", ordinary stuff from any home diy store. Cheers Christian.
#4 | |
#5 |
Is that what they are learning at the ENA?
#6 |
What is ENA?
#7 |
One of the (if not the) best french school of politics
#8 | |
Assuming you measured these drivers with Just MLS did you actually use the bafflestep thingymabob in the merge combine thingy when you add the near and farfield responses of the woofer together??
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#9 |
I did not measure anything, I just listened and have simulation diagrams. As said above, this is based on a kit, I just modified the housing and the quality of the x-over parts, mainly capacitors. The bafflestep i hope has been be taken into account by the developers. Cheers Christian.
#10 | |
Lovely looking speakers! Also look expensive.
How'd you manage 95db, I thought those woofs were in their mid 80's? Quote:
. "Who cares what things really LOOK like to you , I'll convince how they really are."Good school, actually (IMO, etc). Cheers |
| I finished my first speaker project | patherb | Multi-Way | 2 | 12th March 2009 07:00 PM |
| Finished - Pics of my new TL Speaker :) | Xmax BR | Subwoofers | 4 | 10th October 2006 12:10 PM |
| My new speaker project pics | nate | Multi-Way | 13 | 5th November 2004 12:55 AM |
| First project: finished! (pics - 250KB) | hegestratos | Solid State | 5 | 17th September 2004 02:45 AM |
| Finished first speaker project! | Bikeman | Multi-Way | 8 | 25th November 2003 05:52 AM |
| Page generated in 0.12682 seconds (74.41% PHP - 25.59% MySQL) with 10 queries |
