I am a novice with a whole lot of questions, so please bare with me.
I am a electronics engineer 6-5months back i designed a amp & Subs for my brother who's a DJ, fine the amps are perfectly working since then. Basically i made 12" woofers on my own but could not measure the thiele parameters so couldn't design the boxes, did a guess work, and luckily those subs also sounded good. As I always like to design perfect things, I searched the website for measuring thiele para, and found it on ESP Site. After measuring the parameters i found the following. VAS - 75.19l Fs - 54Hz Qts - 0.870 Qms - 5.750 Qes - 1.020 Now I simulated this on WINISD but couldn't come to a conclusin what enclosure size, what fb to use and port size, please suggest me the best ported design I could do with this driver. Now one more thing I wanna know as how to select a best driver i.e. what parametrs i should look for when selecting. so that i can improve my driver on that basis, what all affects the change in VAS, Fs, Q etc. Regards. |
#2 |
That Qts of 0.870 makes life difficult in a reflex box! Using WinISD beta 0.44 the best I could get was 343 litres and 41.7 Hz. You could go all-out and try a 6th order bandpass with the rear chamber 400 litres at 35 Hz and the front chamber at 100 litres at 70Hz.
#3 |
OK but I wanna know as how to select a best driver i.e. what parametrs i should look for when selecting.
As i have made this driver on my own, I want to know what all affects the change in VAS, Fs, Q etc. Cause now i am making an 15" Driver, so i will select cone, coil, frame and magnet which should give a good thiele parameter as needed. |
#4 |
#5 |
Do you want to say you were building it up from scratch ?
Regards Charles |
#6 |
For a bass reflex box, I like a Qts of 0.5.
Lower values give a droopy response; higher values give a big peak before they roll off. |
#7 |
look here:
Diy dynamic driver for a spreadsheet tool I posted that helps you figure out where the Thiele-small parameters come from.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#8 |
WinISD Pro from http://www.linearteam.dk/ is a great tool.
When selecting a sub driver for PA, make sure you have: high power handling (>500W), high sensitivity (>90dB/W@1m), relatively low Fs (less than 35Hz), etc. Qts depends on what kind of box (or lack thereof) you'll be putting it in. |
#9 |
Building or selecting a driver for a reflex box?
Here is a good place to start. The Classic Reflex Box, so named by Thiele and Small, and the term was accepted. Basically, a driver with a Qts of 0.38, (or 0.4, it's okay to round off), goes into an enclosure equal to it's Vas, is tuned to it's Fs, and gets flat response down to it's Fs. Example A: Driver A has the following parameters: Fs=30 Hz, Vas =60L, Qts=0.38, (or 0.4) The ideal box is 60L, tuned to 30 Hz, which gives flat respnse down to an F3 of 30 Hz. Example B: Driver B has the following parameters: Fs=42 Hz, Vas =40L, Qts=0.38, (or 0.4) The ideal box is 40L, tuned to 42 Hz, which gives flat response down to an F3 of 42 Hz. Reflex boxes work well with Qts ratings other than 0.38, of course. Actually, they work well with Qts ratings between 0.25 and 0.5. As a rule of thumb, with Qts ratings below 0.38, the ideal box will be smaller than the Vas, tuned higher than the Fs, and have an F3 above the Fs. Drivers with a Qts higher than 0.38 will have ideal boxes larger than the Vas, will be tuned lower than the Fs, and have an F3 below the Fs. But the Classic Reflex box of Qts=0.38, box volume equal to the Vas is a good place to start. Anyway, build or locate a driver with a Qts between 0.25 and 0.5, and come back to us and we will show you how to build a reflex box specifically designed for that driver.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#10 |
Thanks all who responded for the support
Now I have made a good 12" driver whose Fs is as low as 26Hz, and it sounds very perfect in a 45liter ported enclosure. Although its vas has increased, and has a Xmax of 14mm. Regards, Sonu. |
| Para feed choke | nhuwar | Tubes / Valves | 2 | 14th August 2008 01:43 AM |
| Para-Magnetic Current Amplifier | Tyimo | Solid State | 14 | 13th January 2008 09:55 AM |
| for Thiele calculations, which is better? | Lito | Multi-Way | 4 | 17th July 2004 03:31 AM |
| Pronunciation - thiele.... | 5th element | Multi-Way | 20 | 12th May 2004 12:14 PM |
| Page generated in 0.12549 seconds (87.43% PHP - 12.57% MySQL) with 10 queries |
