Old 13th May 2004, 10:04 AM   #1
Mark25 is offline Mark25  United Kingdom
Mark25's Avatar
Question bass-mid intergration?
All,
do bass and midrange drivers intergrate better if they are of the same cone material?
is there a time delay/phase adj circuit that can be intergrated into the ESP active X-overproject09 to further aid the bass-mid intergration process? would this totally negate my first Q?
Cheers
Mark
Old 13th May 2004, 10:27 AM   #2
IMO the "same material" is a fallacy, its not a major issue.
Your second question :
At bass / mid crossover frequiencies wavelength driver offset
is minimal compared to the inherent phase shifts of the crossover.
Time delay is only relevant to mid / tweeter integration.
Phase delay / manipulation is an inherent part of the crossover
design, again driver offset only needs considering for M-T c/o.
sreten.
Old 13th May 2004, 01:21 PM   #3
Mark25's Avatar
I was on the understanding that i would have minimal phase shift problems from the crossover because it is phase coherent.
Any idea how i'd intergrate phase manipulation into aformentioned active X-over for M-T c/o. As i guess i'll still need it for that c/o?
Cheers
Mark
Old 13th May 2004, 05:14 PM   #4
Ken L is offline Ken L  United States
Default Sreten is so knowledgeable
That I hesitate to disagree with him _grin_
I have learned more than one or two things from Sreten's posts, but I gotta disagree on this one point -
Under certain circumstances ( which I happen to have) where the bass is physically offset by around 14" to the front or so relative to the mid/full range driver in the horn, there is an audible difference.
Using a digital crossover, I set the delay initially by measuring and then to confirm, I had my wife spin the dial while I listened.
As the delay increased, the sound from the subs seemed to be physically moving upward toward the horns above. When it sounded as if the subs were coming out of the center of the horns above them, I stopped. Of course what is happening is that the horns are reproducing the overtones and the subs are blending with overtones.
Crossing at 133 hz, 52 DB NTM slope
Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day
Old 13th May 2004, 07:47 PM   #5
Mark25's Avatar
This is just the sort off feedback i've had from previous posts Ken.
"A crossover that sums electrically will not sum acoustically", and suchlike.
So, i have taken heed of this advice and that's why i'm looking for something that can give adjustable delay to my active analogue X-overs. Although in truth, i'm finding my current active 300Hz crossover pretty seamless.
Mark
Old 13th May 2004, 08:18 PM   #6
Default Re: Sreten is so knowledgeable
....where the bass is physically offset by around 14" to the front or so relative to the mid/full range driver in the horn, there is an audible difference.
Ken L
I was referring to a typical bass unit and midrange on a baffle.
If your digital c/o has the facility by all means use it, it gives
you an extra degree of freedom in the crossover design.
However even with a 14" offset using passive crossovers the
best you can do is manipulate the phase response of the c/o,
for bass to mid c/o a delay network is out of the question.
sreten.
Old 13th May 2004, 10:13 PM   #7
Default Re: Re: Sreten is so knowledgeable
sreten.
I prolly took that too literally _grin_
Best regards
Ken L
Dipole bass or Ripole Bass? MJL21193 Subwoofers 13 15th September 2008 07:42 AM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 09:18 AM
Page generated in 0.10033 seconds (75.39% PHP - 24.61% MySQL) with 10 queries
