Any success with dome midrange?
Old 13th May 2004, 06:42 AM   #1
Ap is offline Ap
Ap's Avatar
Question Any success with dome midrange?
Have been doing some modelling on both the Jaycar & Vifa dome mids (3") and it seems the xover to woofer integration is really tricky requiring higher order low-pass on the woofer.
http://www1.jaycar.com.au/productVie...&priceMin=&pri
ceMax=&SUBCATID=434
or
http://www.d-s-t.com/vifa/data/d75mx-31-08a.htm
Has anyone had success with them?
Old 13th May 2004, 11:04 AM   #2
R.I.P.
Yes it is extremely tricky as c/o is usually in the middle of baffle step.
Added to that fundamantal resonance suppression and excursion
limits of the mid-dome also need careful consideration.
An "off the shelf" crossover as suggested by Jaycar is an utter no-no.
sreten.
Old 14th May 2004, 05:28 AM   #3
Ap is offline Ap
Ap's Avatar
Definitely wouldnt go for an 'off-the shelf' xover.
I seem to get reasonable response using both resonance & impedance Eq, but the parts count for xover gets a bit on the high side (8 components).
Old 14th May 2004, 12:33 PM   #4
Karoliina is offline Karoliina  Finland
Karoliina's Avatar
I think the dome midrange could be used in the
center of a waveguide to overcome the baffle problem.
There is one thing to note though: The dome must
not be soft material or you will end up with distortion.
Soft domes are not suitable to waveguides.
Aluminium or titanium dome should work (I suppose).
I haven't tried a waveguide with a dome midrange yet,
but I suspect that it might work with no problem
(of course by assuming that there is also a similarly
sized and shaped waveguide for the tweeter driver).
Old 14th May 2004, 12:53 PM   #5
gary f is offline gary f  Canada
gary f's Avatar
There is some good design using dome midrange such as Vifa D75, Morel MDM 55 or LPG textile dome. But I never heard them.
It is sure that crossover design is easier with a cone mid but the dome design is nevertheless attractive....
F
Old 16th May 2004, 11:33 PM   #6
Ap is offline Ap
Ap's Avatar
Karolina - by waveguide I guess you mean a type of horn?
Garyf - any more info on designs using the d75/mdm55 or LPG > any links on the web?
Thanks.
Any success with dome midrange?Hide this!Advertise here!
?ITT? dome midrange Cloth Ears Multi-Way 11 14th March 2013 09:12 PM
looking for t/s parameters - RCF M50 dome midrange robbie_cro Car Audio 0 10th June 2007 05:27 PM
HI-VI, DMB-A Dome Midrange ttan98 Multi-Way 0 3rd February 2007 02:24 AM
Midrange: Dome or Cone? Mos Fetish Multi-Way 40 11th April 2005 06:52 PM
Discussion on dome midrange gary f Multi-Way 7 28th October 2004 07:17 PM
