Now I have heard that it is necessary when passively OXing to HP about two octaves or so above the tweeter's Fs. I assume that this has chiefly to do with the impedence bump exhibited at Fs, so is such a great margin necessary when XOing pre-amp?
To be slightly more specific.... can I XO this tweeter at 12dB/oct @ 1500Hz (right about at Fs), or will it over-excurd? http://www.apexjr.com/SDTGraph.htm |
#2 |
From a quick look, I'd try for ~3kHz at least. It looks like it would distort impolitely below that with yr x-over. Indeed, maybe a LR 4th at ~3k would be indicated
#3 |
Actually you need more than 2.5 octaves distance between the crossover cut-off frequency and the driver's Fs, for a 6dB/oct slope crossover. The goal is for the driver to "see" the smallest possible impedance towards the crossover near its Fs. If you need to get closer to the Fs, the highest the x-over's order, the better.
#4 |
But if the tweeter is a lot more efficient than the bass unit, then it is wise to have an 'L' attenuator on the tweeter so that the crossover still sees an 8 ohm (or whatever is required) load. This attenuator will help a lot to prevent the crossover output seeing a big rise in impedance at the Fs of the tweeter.
Whatever you do, don't attenuate the tweeter with a single series resistor, this doesn't help at all! |
#5 | |
Cheers |
#6 |
In general it's not a good idea. For the XO to work properly, it really needs to see a resistive load. Now a tweeter has a rise in impedance at resonance, which means that the XO attenuation will be lower (perhaps much lower) at the Fs of the tweeter, just when you want it to be rolling off nicely.
If you attenuate the tweeter with the correct L-pad, then the L-pad will be designed to provide a nominal 8 Ohms (or whatever is required) on the output of the XO high-pass section. If you do the simple calculations you will see that the more attenuation you have in the pad, the smaller change there will be to the impedance presented to the XO as the impedance of the tweeter changes. If you simply attenuate the tweeter with a series resistor, then the XO will need to be designed to give the correct filter response with the higher Z load, and the load impedance will increase at the tweeter FS, meaning that the filter will not be meeting the design parameters at this frequency. |
#7 |
Thanks. Nice explanation.
I do use a single resistor in my crossovers (1st order series) instead of an L-pad as it just sounds better (don't know why). Normally it's only to attenuate about 1-4dB. So, if I'm reading correctly, as long as the design takes the extra impedance into consideration with the actual impedance (not nominal) of the tweeter at the xo frequency it should be cool but you get less attenuation at the Fs than with an L-pad. Cheers |
#8 |
Ouroboros is right about the use of just a series resistor for helping the power handling of tweeter.. which I think is how he is referring to it in this case...it does help a bit, but if you want to use a tweeter nearer its Fs and the sensitivity is a lot higher, then L-padding can be very helpful.
In the series x-o things are a bit different... here we often use the series resistor as a balancing resistor and it is particularly useful for this when there is not too much difference in sensitivity. You need to remember that using a series resistor on the tweeter in a series resistor actually pushes a bit more through the woofer because of the impedance balance change. In other words, we are actually using the impedance imbalance to shape the response !! If we do have a big difference between sensitivities in a series x-o, an L-pad on the tweeter is still recommended. |
#9 |
No, no, no, Pre- Amp. Impedence no object, right? I'm talking about a LR between the CD player and the amp, thus Active XO; custom vs. out-of-the-box
Now, would that be a problem? |
#10 |
Soory, I jumped in without realising you were refering to a XO between the pre-amp and the power amps.
Why not use an active XO here? It makes things a lot easier. |
| Page generated in 0.12616 seconds (79.34% PHP - 20.66% MySQL) with 10 queries |
