diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? (http://www.diyaudio.com/forums/multi-way/33852-whats-closest-i-can-get-4-ohm-load-using-3-single-coil-6-ohm-drivers.html)
The Paulinator 11th May 2004 12:54 AM
Anybody have a good wiring scheme for that?
getafix 11th May 2004 01:23 AM
how about 2 speakers in series then they are parallel to the remaining speaker
Cloth Ears 11th May 2004 07:23 AM
Hey The Paulinator,
I did a little bit of playing around with various ways of wiring up some cheap drivers I picked up (from Dick Smith, I think).
getafix gave you the wiring to get a 4ohm load: 2 drivers in series wired in parallel with one driver gives a 4ohm load.
What I found is that when I was driving these 3 drivers (or in my case 6 - I had 2 sets of 3 wired in parallel for an 8ohm load) was that the 'single' driver was working twice as hard as the 2 drivers in series. This was only an observation - not measured - but it was fairly easy to hear that one was louder and the 'finger on the cone' test showed more excursion.
I just figured that with half the resistance of the series pair that more current was flowing. Anyone know if this is so? Or was I imagining it?
Cloth Ears 11th May 2004 07:24 AM
Woops - make that "I had 2 sets of 3 wired in series for an 8ohm load"...
sreten 11th May 2004 08:46 AM
Originally posted by Cloth Ears
Hey The Paulinator,
Ermm.................
Not quite, the single driver is working 4 times
as hard as each driver that is wired in series.
For a set of six 6 ohm drivers, 6-6||6-6||6-6,
three sets of two series in parallel for 4 ohms.
For three 6 ohm drivers the best choice is adding
another driver and wiring series / parallel 6ohms,
or just use two for 3ohms.
:) sreten.
azira 11th May 2004 03:26 PM
:) sreten.
Or a favorite sreten style answer.....
Wire 2 in parallel for 3-ohms and use the 3rd for a .33 so you can correct for some BS.
sreten 11th May 2004 04:15 PM
Yes, but that will give you 2 ohms in the bass, 3 ohm midrange.
The two parallel 6 ohms could be wired as a 0.5 way for BSC.
This would be 3 ohm in the bass, 6 ohm in the midrange.
For three drivers :
The same can be achieved by using two drivers for bass and crossing
over to the other driver for midrange at ~ the baffle step frequency.
The 0.33 way would give 3.5 dB of BSC and be presumably MTMM.
:) sreten.
The Paulinator 11th May 2004 06:17 PM
Actually, I have access to 6 of these, so I might do that instead. Although I hope my 120 watt RMS sub amp will handle all of those OK.
The Paulinator 11th May 2004 07:02 PM
Actually, will the average sub plate amp handle a 3 ohm load at all?
markp 11th May 2004 07:04 PM
A halfway decent one will handle 3 ohms.
Copyright 1999-2017 diyAudio
