Old 10th May 2004, 04:09 PM   #1
Send a message via MSN to officeboy
Default Nwwa PR-15 prize! (And cheap Shiva from there too)
I've been busy since, designing a plate amp, getting parts here and there, and the box is nearing it's final stages. (The amp just barely getting started.)
This box is really REALLY big. And getting REALLY heavy. I think it's gonna look really nice when it's done though. I'm pretty much following Adire's big box recommendation at 143L .
http://home.comcast.net/~0fficeboy/shiva/index.html
Anyway, I just wanted to share.
Click the image to open in full size. Click the image to open in full size.
And I guess I could use some tips on finishing the mahogany if anyone has some good ideas.
Oh, thanks Dan W. and Adire
Old 11th May 2004, 01:33 AM   #2
moving_electron's Avatar
Location: Where the rain does fall but the trees grow tall
Default Re: Nwwa PR-15 prize! (And cheap Shiva from there too)
You are a lucky lucky guy.
Be sure to post the completed pic.
By finishing finishing the mahogany I assume you are going to apply mahogony veneer?
Old 11th May 2004, 03:09 AM   #3
Timn8ter's Avatar
Thanks for sharing. It would be great to hear from the other people that won prizes and what they're doing with them. Keep us informed.
Old 11th May 2004, 03:49 PM   #4
Default Re: Re: Nwwa PR-15 prize! (And cheap Shiva from there too)
If you go to the site, you can see that it's all getting covered in mahogany veneered plywood, in fact it is all covered now.
And I will post lots of pics when I get it done, And foolish me for not thanking Timn8ter for having this great idea of an audio event.
Old 11th May 2004, 04:23 PM   #5
For finish I am a very big fan of the Formby's Tung Oil finish, low luster version. It is pretty easy to find.
Mind you I am not really a big fan of normal tung oil as it hasn’t done very well for me. The Formby's tung oil finish name is a bit of a misnomer because the Formby's is really a varnish with some tung oil in it. So in other words, I don't think it should be confused with other tung oil
The best way to use it is to wipe it on in thin coats with a dust free rag. The surface dries rapidly this way so you do not get much dust from the air. Use good ventilation! After the first coat you knock back the fibers by running some fine steel wool lightly over it.
Then you build up the coats. They go on fast so it is not much bother for each application. Be patient as it is tempting to put on a thick coat. The can says it covers in two coats. That really is not a good stopping point as the results will look thin. The real benefit comes from 4-5 coats of thinly applied finish. It really brings up a very rich finish that fully highlights the grain and shimmer of the wood. The 4-5 coats produces what best can be described as a semi-gloss. If you then want it glossier then apply the gloss version on top of this, but I doubt you would end up doing this.
It is very durable finish one it fully hardens. As with all oil based finish it will benefit from a beeswax based or oil based polish of some sort a few months down the road to keep it rich and deep looking. But spray can polish has worked pretty good also.
Black Gate Sale - Half Prize Pocoyo Swap Meet 10 16th May 2007 01:36 AM
and the prize for stupid act of the week goes to..... wintermute Multi-Way 34 22nd November 2005 11:33 AM
NWWA DIY Audio Meet 2004 NEWS Timn8ter Multi-Way 10 18th April 2004 04:29 AM
NWWA DIY Audio Meet 2004 Timn8ter Tubes / Valves 0 8th March 2004 01:13 PM
NWWA DIY Audio Meet 2004 Timn8ter Swap Meet 0 8th March 2004 01:09 PM
Page generated in 0.11738 seconds (70.78% PHP - 29.22% MySQL) with 10 queries
