Ok so I own an vellmann multimeter that has these specifications(the best I could find around and aford)
Features Specifications DC voltage: 200m/2/20/200 /1000V basic accuracy: ±0.5% (±0.8% for 1000V range) input impedance: 10Mohm maximum input: 1000V AC voltage: 2/20/200/750V basic accuracy: ±0.8% (±1.2% for 750V range) input impedance: 10Mohm frequency range: 40-400Hz maximum input: 750V DC current: 200µ/2m/20m/200m/20A basic accuracy: ±0.8% (±2.0% for 20A range) overload protection: 0.2A (20A range not protected by fuse) AC current: 2m/20m/200m/20A basic accuracy: ±0.8% (±3.0% for 20A range) overload protection: 0.2A (20A range not protected by fuse) resistance: 200/2k/20k/200k/2M/20M/200M basic accuracy: ±0.8% (±1% for 20M range) overload protection: 250V I used this method : http://sound.westhost.com/tsp.htm So RS is an 8.3 Ohms resistor in series with my driver(Re=3.9ohms). I got this measurements For 200Hz Vs is 810 mV Is=66.393 Fs=23 Hz Vm=266 mV Im=32.028 Rm=16.97 ro=2.07 Ir=46,127 Vr=382.854 Fsh=29,4Hz Fsl=17.3Hz Added mass(I used this method for VAS) Mass=22g Fb=19.2Hz I obtained Qts=0.720 Vas=674.594 litres I know that the measurements are not very accurate because of the frequency stability of the multimeter but testing it,it turned out that the error was under 20% untill about 15Hz when it got to about 50%. Assuming the measurements allmost corect could you check the calculations for me and tell me if you see anything wrong... The driver is a Senon (Chineese) and is 12" in diameter, magnet 40 Oz and 2" voice coil. Here is a picture. Thanks. |
#2 |
After playing a bit with winisd here is what I found...What would you do?
Please guys I really need some advice and help.... Here is the pic for a box of 500litres using the data I measured... |
#3 |
VAS seems a bit high...
| Ratio of driver quality vs result ? | oaristys | Multi-Way | 86 | 11th June 2009 04:20 PM |
| Infinite Baffle Construction for Driver Measurements | Tector | Multi-Way | 2 | 19th March 2009 08:31 PM |
| Single Ended, Single driver: In-room distortion measurements | Gerrit Boers | Full Range | 4 | 27th November 2007 08:12 AM |
| Simulating Zaph's L18/TBFCG design using his separate driver measurements | Jay_WJ | Multi-Way | 0 | 20th April 2007 10:00 PM |
| Page generated in 0.09009 seconds (63.61% PHP - 36.39% MySQL) with 11 queries |
