Dumb Q., but how do bi-polar caps affect the phase of a signal?
I remember it's possible to make a bi-polar by putting two polarised electros in series, but with the same two poles (say+) connected together; are commerical bi-polars just the same thing in a single package? cheers, Pete McK |
#2 |
The phase shift will be the same as with any other cap of the same value.
Commercial bipolar electrolytics are formed so that there is an insulating interface layer between the foil and the electrolyte on both foil surfaces. The effect is indeed similar to two series-connected back-to-back electrolytics. The problems with bipolar electrolytics are that the tolerance is poor, (and can vary as they get old), and that leakage can be high, although that is not usually an issue in crossover networks. |
| use normal caps as non-polar caps | bigpanda | Parts | 10 | 23rd June 2011 11:25 AM |
| WTB: Mundorf Bi-Polar caps | vadimgal | Swap Meet | 0 | 27th January 2008 03:29 AM |
| Bi-polar vs poly caps. in xo . | marchel | Multi-Way | 4 | 7th January 2008 12:15 AM |
| Non-Polar caps to cathode bypass | s2kov | Tubes / Valves | 4 | 13th September 2004 08:39 AM |
| Which replacement caps for 47uF/16V non-polar? | Sampsa | Parts | 0 | 7th June 2004 03:29 AM |
| Page generated in 0.08198 seconds (69.73% PHP - 30.27% MySQL) with 10 queries |
