Old 9th May 2004, 02:54 PM   #1
wigginjs's Avatar
Default Wayne J's Low Cost Dayton 5.1's as Dipoles
I'm currently building a set of 3 di/bipolar speakers for surrounds in my home theater system using the design by Wayne J. For each of the di/bipolars I am building what is essentially 2 of the original designed speakers back to back and wiring them in parallel either in-phase for bipolar or out-of-phase for dipolar. I'm curious how this will effect the frequecy response and (especially) the impedance curve. Will this result in a 4ohm load (nominal)? Will there be any dips to very low impedances I should be aware of? Any other comments on this design would be much appreciated.
The Four Chairs
DIY Home Theater
Old 9th May 2004, 06:38 PM   #2
I'd give up on the dipolar, unless you want no bass.
Classic bi/di polars use a single bass unit and two cone type
midrange treble drivers, only the phase of the MTs is changed.
sreten.
Old 9th May 2004, 10:08 PM   #3
wigginjs's Avatar
Would leaving the woofers in-phase and only changing the phase of the tweeters give me the effect I desire without losing bass response? Please elaborate on how this speaker design would be handled by an amplifier if two were wired in parallel...
The Four Chairs
DIY Home Theater
Old 10th May 2004, 08:44 AM   #4
The phasing connections do not affect the amplifier load.
Just wiring the tweeters out of phase will work, but the
effect is more marked when mid / tweeters are used.
But the problem here is phase cancellation at crossover
with the main bass driver if they are phase aligned.
The best design for this is purposfully designed with a
90 degree phase difference at crossover, so in and out
of phase are both 90 degrees, and the response is
optimised for both phase connections.
sreten.
Old 10th May 2004, 01:38 PM   #5
wigginjs's Avatar
Anyone know of any good DIY dipolar surround designs?
The Four Chairs
DIY Home Theater
Wayne Kerr B424 help Clif225 Everything Else 1 10th September 2006 01:50 PM
Eros by Wayne Jaeschke opinions andrew01 Multi-Way 5 26th May 2006 05:04 PM
6 Wayne J Dayton Home Theater Speaker kits (woofers, tweeters, xovers) wigginjs Swap Meet 0 27th February 2006 01:49 AM
Wayne, Nelson and Karen: New Pearl was born last night dshoaf Pass Labs 0 3rd January 2004 04:54 PM
Wayne Volume Control patent official yet mlloyd1 Pass Labs 4 6th December 2002 11:49 PM
Page generated in 0.09685 seconds (76.64% PHP - 23.36% MySQL) with 10 queries
