Just wondering if the rated frequency response of a driver is relative to a certain volume. By this I mean if a driver is in a smaller volume of air can it have a broader freq response, such as headphones. Headphones have a very small diahgrams, with little excursion, yet are rate as 40-18K (or whatever), but at a very low volume, and it in a very small space. So my question is could a driver (say a tweeter which might be rated as 3k-20k) have a broader response (say 200-20K) if it were used a small conceiled area?
I enjoy my organic shapes..... |
#2 |
Sure. The smaller the environment, the higher up in the response "room gain" (loosely speaking) occurs - that is, where the lower frequencies are increasing in volume by a certain level per octave downard.
#3 |
Basically for tweeters no.
Excursion requirements come in with a vengeance at a phenomenal rate once you start dropping the lower cut-off frequency point. |
#4 |
Ok so a 4" woofer in a very small displacement at a low volume, would have an amazing frequency response then? Say if you measured it inside a tupperware container?
How are headphone diaghrams different than a tweeter? They <headphone> don't have much excursion either do they?
#5 | |
#6 |
Headphone drivers are mounted in the ultimate close coupled horns, the human ear canal. You're also talking about the SPL at 0.05M unless you have a huge head. You can try the maths if you want and you can see what the excursion requirements are.
Mark The king of all that is evil has left the building |
| Frequency response | 2litre | Analog Line Level | 5 | 31st May 2006 07:00 PM |
| frequency response | pmarcouxx | Digital Source | 2 | 20th July 2005 07:43 PM |
| opt frequency response | nkg | Tubes / Valves | 3 | 29th August 2004 06:31 AM |
| Doubts on Phase Response and Frequency Response | dumrum | Multi-Way | 11 | 5th April 2004 10:39 AM |
| frequency response of air | mikelm | Everything Else | 8 | 29th February 2004 07:17 PM |
| Page generated in 0.09061 seconds (72.54% PHP - 27.46% MySQL) with 10 queries |
