Old 8th May 2004, 02:51 AM   #1
SWhite is offline SWhite  Canada
Default clay wrapped around voice coil
I removed the dust covers in preperation of redoing the surrounds on a pair of woofers and found a substantial amount of clay wrapped around the voice coils.
I've never seen anything like that before and was curious what you thought.
I'm going to leave the dust covers off for a while and see how much difference there is with out clay and then decide which I prefer. I could use the increase in sensitivity.
Old 8th May 2004, 09:26 AM   #2
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Nice pic. I can only think that it is used to add mass to the cone and you would thus reduce efficiency and fs, and extend low end response. It would be strange not to just use a heavier diaphram though, so maybe it's a way for the manufacture to fine tune the same basic driver slightly. I'm just stabbing in the dark here.
The only other ring you would put around the top of the VC is a shorting ring, but it wouldn't be clay.
Or maybe the clay somehow aids heat transfer away from the aluminium former.
Depending on how much the clay weighs and consequenctly affetcs T/S params, it may change box requirements so you should keep that in mind. Worse still, if it is used to keep the VC cool, you could be reducing its power limits.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 8th May 2004, 09:37 AM   #3
The clay will impact the high frequency response of the driver.
The upper frequency limit of a driver is when the voice coil
effective mass = the effective massloading of the cone, the
clay here is being used to limit high frequency response.
sreten.
Old 8th May 2004, 11:34 AM   #4
Svante is offline Svante  Sweden
Svante's Avatar
sreten.
??? I have never heard this, could you elaborate on this a bit?
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 8th May 2004, 01:41 PM   #5
Just something I've known for a long time, can't remember
the source, but its certainly the main purpose of the clay ring.
Its accepted the effective radiating diameter of a cone decreases
above a certain frequency with frequency, and at some point the
mass of the voice coil will begin to dominate the response.
Hence a short coil in a long gap driver will have more treble than
a long coil in a short gap approach. I've also seen Tannoy 0.5
way bass drivers fitted with a large central plastic slug, this may
be extra mass loading and control of roll-off in the midband.
sreten.
Old 8th May 2004, 02:01 PM   #6
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default mass
Just mass loading, with the usual affect on HF too.
Old 8th May 2004, 03:52 PM   #7
Svante's Avatar
sreten.
I don't understand how added mass could affect the FR. I can see that if the effective surface decreases, the radiated power will too. But that effect would be the same with and without the clay, right? I can see that the effectve mass of the cone decreases as the effective surface does, and that this would compensate to some extent the drop due to loss of area. Do you mean that the relative mass drop is smaller if clay is added and that this compensatory effect is reduced?
Old 8th May 2004, 04:49 PM   #8
pinkmouse's Avatar
The added mass will reduce the resonant frequency of the driver, however it will also decrease the efficiency as well, as the coil has to work harder to move the cone.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 8th May 2004, 04:56 PM   #9
Svante's Avatar
Yes, of course, that I understand, but here the issue was the rolloff at high frequencies.
Old 8th May 2004, 05:04 PM   #10
pinkmouse's Avatar
Sorry...
Well, as far as I understand it, the compliance of the cone material acts to damp higher wavelengths from propagating out from where the VC joins the cone. This is why higher frequency drivers tend to be both smaller, and use thinner cone material than lower order drivers.
Al
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
ASV voice coil ? Nihilist Multi-Way 4 1st October 2006 07:16 PM
an amp for each voice coil? speekergeek Multi-Way 1 12th December 2003 02:31 AM
constructing sub voice coil emarald Multi-Way 3 5th April 2003 06:51 PM
Page generated in 0.13406 seconds (79.66% PHP - 20.34% MySQL) with 10 queries
