Old 7th May 2004, 10:07 PM   #1
Default narrow vs wide baffle and port location....?
Either I want to go with a narrow baffle width... actually just a little wider than the driver... or a bookshelf style speaker for use with stands.
with the narrow baffle I can get away with a smaller inductor for the rear 0.5
Any other advantages or disadvantages???
Also, I have 2 ports to place, one for each of the driver on front and back.
Should these go right next to the driver?? Or should they be placed near the floor (in the narrow baffle version).
HELP!!!!!
Thanks!!
Old 8th May 2004, 04:46 AM   #2
GM is offline GM  United States
GM's Avatar
In the BW where the box dominates (<(2*Fs)/Qes), having the driver near a cab side wall has no effect on it, but if it's used up high enough for eigenmodes to occur, then of course they must be well damped. This damping will acoustically load the driver, which may change its sonic balance. Experimentation with different width/depth aspect ratios and stuffing density is the only way to find out where tonal degradation occurs in this case.
WRT vent placement, the closer they are to the driver, the greater the peaking at Fb, so for smoothest response having them near/at the bottom is usually best. That said, if you prefer the 'west coast sound', place them near/at the driver's centerline like Altec did.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th May 2004, 05:10 PM   #3
Default for a bipole?
so for a bipole which is better?
a narrow baffle or a wide one?
Thanks!!
Old 9th May 2004, 09:19 PM   #4
GM's Avatar
Since there's no baffle step due to being bipolar, it doesn't matter.
GM
B20's, sealed, wide vs narrow baffle? 2litre Full Range 15 21st March 2010 08:30 PM
Port Location ERICSPEEd Multi-Way 4 3rd December 2008 10:50 AM
Narrow, shallow rectangular port cabbagerat Full Range 7 14th February 2008 10:03 AM
Fr125S: wide or narrow baffle bro Full Range 28 1st November 2006 09:15 PM
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 12 12th January 2004 03:43 AM
Page generated in 0.08455 seconds (71.40% PHP - 28.60% MySQL) with 10 queries
