Old 7th May 2004, 12:37 PM   #1
Buzzurd is offline Buzzurd  United States
Default blowing fuses KSW12
I am just a novice when it comes to stereo equipment so please be kind.My girlfriend had my system cranked up while I was at work the other day.I returned home to find my Klipsch KSW12 had a blown fuse.I replaced the fuse with recommended 250v 1.5 amp sloblo.Popped immediately.I removed amp and noticed the input power supply goes directly to the transformer.I am assuming the short is in the transformer.Would like some input on this and maybe some other possible causes.If it is the transformer where can one be purchased?
Old 7th May 2004, 01:25 PM   #2
li_gangyi's Avatar
might be the outputs which are goner...does ur amp (I suppose) have protection relays??
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Keep Blowing Fuses Whiting Tubes / Valves 9 11th September 2008 09:44 PM
Car Amp help? Fuses blowing... Tolo Car Audio 1 3rd December 2007 01:42 PM
Blowing fuses balance Tubes / Valves 2 5th March 2005 02:16 AM
blowing fuses homegrown45167 Car Audio 2 22nd October 2004 12:16 PM
The Fuses Just Keep Blowing raffir Chip Amps 19 22nd June 2003 03:49 AM
Page generated in 0.06552 seconds (71.96% PHP - 28.04% MySQL) with 10 queries
