I bought an Adire Brahma MKI used to try in a vented box for home theater. Does anyone know where I can find specs for this driver? It looks like Adire Audio only lists specs for the Brahma MKII.
Thanks. |
#2 |
hi
plase check the adire site , you should be able to get ure info there - or just wait a while dan of adire audio will help you out i have seen that he takes care of all matters regarding his drivers prompltly here ! suranjan transducer design engineer |
#3 |
Close enough to the Mark II parameters that they are interchangable. When we rev drivers, we try to keep the T/S parameters within manufacturing tolerances, so applications don't change. The move to the Mark II added a bit more linear stroke (yeah, 27.3mm one way wasn't enough...
![]() Dan Wiggins Adire Audio |
#4 |
Thanks guys!
#5 |
hi
dan what if i reverse xbl and split the coil winding itself instead is there a problem ? suranjan |
#6 |
I am getting ready to build an enclosure for my Brahma, but I am having trouble downloading the Adire LspCAD. If someone has the program could they relay the preloaded box/port dimensions for the Brahma 12" ported box, tuned to 20Hz.
Thanks, Steve. |
| For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp | tmort | Swap Meet | 5 | 27th June 2009 12:29 AM |
| Where can I find older Adire driver specs? | Finleyville | Subwoofers | 1 | 16th August 2008 03:34 AM |
| Adire Brahma 12 MK II | KBK | Swap Meet | 5 | 8th March 2006 06:22 PM |
| Adire Audio Tempest , Brahma | jadenlinkletter | Subwoofers | 38 | 2nd May 2005 10:26 PM |
| Adire AVA250 amp specs | Grantbo | Subwoofers | 1 | 23rd March 2002 11:44 PM |
| Page generated in 0.08835 seconds (70.78% PHP - 29.22% MySQL) with 10 queries |
