Old 7th May 2004, 01:35 AM   #1
Default Baffled by baffle step
Okay, I'm ready to cut MDF for a set of speakers. They will be fe107e (full range) in a box with width = 5.5", height = 16 7/8". The speaker is 4" in diameter, and will be placed 6 3/4" from the top of the box. I've calculated a baffle step correction circuit two different ways, namely, using a paper that I found on the net written by Martin King, and also using the edge.exe program. The first method give an inductor of 1.5mH, while the second gives 2.75mH.
HELP!
Davy Jones
Old 7th May 2004, 02:26 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
I think that the equation you used (4560/W, right?) originates in Olson's work in the 50's. He calculated these things for spheres and the results have since been applied to baffles of different shapes. The Edge calculates the response for a flat baffle, and also takes the height and width (or any shape) into consideration.
To me it appears obvious that a high baffle should offer more "support" than a square baffle of the same width, and so the f3 frequency should be lower. This would mean that the BSC calculation cannot be simplified to a formula that only contains the baffle width. Also a flat baffle should give more support than a sphere of the same dimension.
On the other hand, it appears as if the baffle step often is not fully compensated, since there is an effect of the room that also boosts the lower frequency.
I sure welcome a discussion on this!
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 7th May 2004, 06:10 PM   #3
frugal-phile(tm)
planet10's Avatar
As far as i have been able to determine this equation is indeed pulled from the graphs Olson published. The baffles were either spheroids, cubes, or rectangles, some with significant 45 degree bevels. It is only a very rough starting point.
The new simulation tools coming out do a much more accurate job of accounting for the actual baffle shape.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th May 2004, 06:32 PM   #4
Svante's Avatar
One reference that I see a lot on fora is this:
http://www.trueaudio.com/st_diff1.htm
It clearly uses the diffraction around a sphere to derive the function 380/W (W here in feet, 380*12=4560) and then magically the diameter of the sphere is assumed to have the same effect as the width of a rectangular baffle of any height.
Obviously, I wrote the Edge program, so you should be sceptic towards me, since I probably am biased. But as far as I understand there must be room for an error in the above reasoning.
Old 7th May 2004, 06:43 PM   #5
I've fiddled around with the F1, F2 fields in edge.exe some. When I set them at 350 and 700, I get an L of 1.8, and the curve looks at least as good as the "suggested" 2.6. So I'm going with 1.8 mH. Thanks for your help, and thanks for the nice program.
Davy Jones
Old 7th May 2004, 06:46 PM   #6
frugal-phile(tm)
planet10's Avatar
When is it coming for OS X? ... i just hate to fire up Virtual PC.
Is the Edge based on Juha Backman's paper?
dave
Old 7th May 2004, 06:54 PM   #7
dave
Better yet, port it to Python/wxPython just once, and quit hassling over OS... uh... hassles.
Davy Jones
Old 7th May 2004, 07:08 PM   #8
frugal-phile(tm)
planet10's Avatar
If i ever get time to write my OS X speaker simulator it will be in Python...
dave
Old 7th May 2004, 08:04 PM   #9
SY's Avatar
(scratches head)
Look, I love simulation programs (I use BDS, a wintel Excel-based program), but xover/eq parts are fast and easy to get. How about (radical idea here) putting the actual speaker in the actual baffle and actually measuring it before putting the xover/eq together? That way, you can order the exact inductor you need- or, more likely, find out that the eq circuit you need is something different than that predicted by any of the simulation software.
I think that baffle simulation is most useful for designing the baffles in the first place. You can choose a size/shape/driver positioning that minimizes hard-to-correct anomalies. The results won't be rigorously quantitative, but qualitative is all you really need at that point in the design process.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 7th May 2004, 08:27 PM   #10
Bill Fitzpatrick's Avatar
Great idea but most don't have the bucks for the measurement software and hardware.
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Baffle Step Calculations? Help! Mutley666 Multi-Way 5 8th April 2005 08:49 AM
baffle Step rgrayton Full Range 33 4th December 2004 11:16 PM
Baffle Step + Sub Aural Dan Multi-Way 7 9th October 2004 08:23 PM
baffle step help. AudioGeek Multi-Way 3 10th February 2004 11:02 AM
Page generated in 0.09693 seconds (89.13% PHP - 10.87% MySQL) with 10 queries
