Active XO; custom vs. out-of-the-box
Old 6th May 2004, 03:02 PM   #1
fortyquid is offline fortyquid  United States
Default Active XO; custom vs. out-of-the-box
IS there any reason not to use a manufactured electronic XO such as this
http://www.partsexpress.com/pe/showd...number=265-128
as opposed to a custom-designed one, if the slopes and crossover points are the same? Assuming there are some difficulties, do you think it would be a step up from passive?
Thanks for the input
*groan*
Sorry for the extremely bad pun
-fortyquid
Old 6th May 2004, 04:04 PM   #2
chris ma is offline chris ma  Canada
chris ma's Avatar
Hello eight fivers,
The same reasoning for speakers, pre-amps, power amps, radios, projectors, coffee tables, cables, interconnects, airplanes, cars, chairs..babies instead of adoptions.... etc.. etc......
To be or not to be DIY
Chris
Old 6th May 2004, 04:16 PM   #3
tiroth is offline tiroth  United States
If you ignore the flexibility of setting slopes, xover points, etc..then it just comes down to component/build quality. In my opinion, though, you can't ignore that.
The commercial unit that has the best mix of features, quality, and price/performance is probably the DCX2496. Most of the cheaper options will require significant compromises to be made.
Old 6th May 2004, 04:44 PM   #4
*chuckle* Way, way, way out of sight. Gimme five years to pay off the college loans.....
OK, so I've never done this before- can I just follow the schematics on WinISDPro and wire them in line between my CD player and my amps? *vauguely* I hear things about impeadence matching.....
Well, here's what I'm looking at. I have decided that there is no point in trying to design a passive XO because ultimately the OX point cannot be consistant throughout the dynamic range of the driver even with the most complex impedence compensators. I am on an extremely limited budget, but thought that if I could design an efficient enough system I could run it on some of those little multimedia amps from ApexJr.com which are cheap enough to allow me to multi-amp the system. http://www.apexjr.com/JBL12.htm
So I figure I'll just wire the appropriate caps and resistors and whatnot between the CD player and the amps and Hey Presto! Much better sound than can be gotten from any passively XOed system. Does this sound right? Is there anything else I need to know? Like about source impedence for instance (I don't even know what it is, I've just heard people talk about it....;-)
Old 6th May 2004, 04:54 PM   #5
The passive "active XO" you describe should work well, as the amps are probably of fairly high input impedance and your CD player probably has a low impedance opamp-based output stage.
You'll have much more flexibility, though, if you use a true active crossover and buffer the inputs and outputs. This can be done very cheaply, as cheap as the unit you posted. Have a look at the "Designing with Opamps" article and the biamping and active XO projects on Rod Elliot's website, www.sound.au.com.
Old 6th May 2004, 05:22 PM   #6
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
The unit from Parts Express will probably be fine but if it's for the home you'll need a 12v or 13.6v power supply to run it.
Old 7th May 2004, 04:59 AM   #7
rbmcginnis is offline rbmcginnis  United States
i am building a pair of electrostatics and have the same dilemma. I am considering a
http://www.behringer.com/CX2310/index.cfm?lang=ENG
because it is fully adjustable and uses AC.
It runs for about $90. Its big brother is about $130.
Let me know what you think.
Old 9th May 2004, 06:22 PM   #8
Is it suicidal to try to take this tweeter to 1500Hz with a 2nd order active XO?
http://www.apexjr.com/SDTGraph.htm
Active XO; custom vs. out-of-the-boxHide this!Advertise here!
Active 3-ways with solen active loudspeaker module soundemon Multi-Way 14 19th March 2009 11:17 AM
Component Suggestion: 2-way active now, 3-way active later CanadianDream Multi-Way 6 3rd August 2007 04:53 AM
Behringer DCX2496 I want to try active biamping using it as the active xover. georgehifi Digital Line Level 3 15th August 2006 07:46 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Copyright ©1999-2017 diyAudio
