Old 6th May 2004, 07:55 AM   #1
dumrum is offline dumrum  India
dumrum's Avatar
Default Xmax measurement
I had come across a means to measure the Xmax of a driver some where on the net, or in DIY, but I just cant recall where..and no means to locate it.
I saw a means by which Xmax of a Woofer can be ,easured with a 1.5 volt cell. Could anyone please tell me how it can be done?
Thanks,
Linoj.
Old 6th May 2004, 11:00 AM   #2
SY's Avatar
A battery will not exercise a driver to Xmax. And you risk blowing the driver if you want to do a real Xmax test, which involves hitting the driver with signals big enough to take the cone/coil out of the linear region.
This is one spec that I don't measure for myself, but either take or derive from the spec sheet.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 6th May 2004, 12:49 PM   #3
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Default Calculate it.....
If you haven't got the xmax but have the voice coil length and air gap height from the spec sheet you can calculate it.
Xmax=(voice coil length - air gap height) / 2
Some drivers you can see under the spider and can get a measurement there but most have the voice coil out of view.
Xmax dallaire Multi-Way 2 25th December 2007 09:47 AM
Xmax measurement KCC Multi-Way 3 6th August 2005 07:22 PM
Xmax mik Subwoofers 12 1st December 2004 04:39 AM
Determining The XMAX OMNIFEX Multi-Way 11 8th August 2004 06:29 AM
Measuring Xmax Doug Multi-Way 16 5th February 2004 11:18 AM
Page generated in 0.11390 seconds (46.58% PHP - 53.42% MySQL) with 10 queries
