How do I use carbon fiber + MDF wood + glass fiber to make speaker?
Old 6th May 2004, 06:45 AM   #1
sonyacer is offline sonyacer  Alderney
Default How do I use carbon fiber + MDF wood + glass fiber to make speaker?
Which material is the best for diy speaker?
I saw some speaker manufacturer use carbon fiber + MDF wood + glass fiber to make speaker. e.g : Rockport hyperion
Any benifit of this treatment?
If I want to diy a speaker cabinet use carbon fiber + MDF wood + glass fiber to make speaker
How do I do?
Any information?
How do I mixture this material?
Old 6th May 2004, 01:35 PM   #2
Mudge is offline Mudge  United Kingdom
I'm not entirely sure how to go about using carbon fibre for speaker building, but a hybrid MDF + GRP enclosure is an interesting idea.
I would get a GRP fabricator (there are a surprising number of them all over the world) to build spherical shells of appropriate volume for your drivers to sit in. I would then build a wooden enclosure around those shells and line the gap with heavy sound deadening material.
Aside from the obvious problem of needing big spheres for certain driver alignments, I can't think of too many disadvantages, and the lack of internal standing waves and reduced radiation from the sides of the speaker would be a big advantage.
Mark
The king of all that is evil has left the building
Old 6th May 2004, 04:38 PM   #3
5th element is offline 5th element  United Kingdom
5th element's Avatar
Carbon fibre is easy to work with really and a hybrid could easily be made. As far as I can imagine, you would create a MDF carcas for the speaker and then cover the carcas in carbon fibre.
You can buy carbon fibre easily enough but its quite expensive. You would then buy the epoxy and place the carbon fibre in it so it gets completely saturated with epoxy then simply lay it on the carcas, in a similar way you have a plastercast put on your foot made out of plaster of paris encrusted fabric.
On the other hand you could make a wire frame out of rigid chicken wire and layer carbon fibre on top of this to make odd shaped loudspeakers. The only problem I can think is the front baffle. You would need a good few layers of CF though maybe 10 at a minimum, you would also need bracing.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 8th May 2004, 09:49 PM   #4
Chris8sirhC is offline Chris8sirhC  United States
Send a message via AIM to Chris8sirhC
dont you have to "fire" or bake carbon fiber?
Old 9th May 2004, 12:08 AM   #5
454Casull is offline 454Casull  Canada
In an oven, yes, to cure the epoxy.
Old 9th May 2004, 12:09 AM   #6
I think it would be more useful to brace CF than to increase its thickness. Its strength is already high enough, but it likes to flex, IIRC.
Old 9th May 2004, 05:18 AM   #7
b-square is offline b-square  United States
b-square's Avatar
Prepreg (meaning it comes from the manufacturer impregnated with epoxy) is not that expensive, but it can be very challenging to work with. Not a good first fabrication project. Stick with good old cheap MDF and wood glue to start.
Old 9th May 2004, 11:51 AM   #8
You dont need to fire CF at all, thats only if your epoxy requres it. Just buy one that doesnt.
Old 9th May 2004, 11:53 AM   #9
I agree thats why I mentioned bracing it
The CF that we have at home however would probably produce a 15mm thick enclosure if done up to 10 layers. If I was going to put in the effort to make a CF enclosure, id sure as hell want to make it well.
Old 9th May 2004, 12:06 PM   #10
wytco0 is offline wytco0  United Kingdom
I like the idea of a Carbon Fibre wrap for cosmetic reasons, buts its strength and rigidity could probably benefit the structure as well.
Has anyone seen a CF wrapped speaker cabinet?
How do I use carbon fiber + MDF wood + glass fiber to make speaker?Hide this!Advertise here!
carbon fiber to make chassis diymax62 Everything Else 1 19th December 2007 05:13 PM
carbon fiber earing Instruments and Amps 8 13th March 2007 06:04 AM
parts express carbon fiber speaker SQ Kid Multi-Way 4 30th May 2004 01:04 AM
Carbon Fiber be used for speaker material? StylinLP Multi-Way 3 15th January 2003 11:51 PM
CArbon fiber enclosure jouch Multi-Way 1 14th March 2002 11:49 AM
Copyright ©1999-2017 diyAudio
