How do I use carbon fiber + MDF wood + glass fiber to make speaker?
Old 10th May 2004, 01:22 AM   #11
Chris8sirhC is offline Chris8sirhC  United States
Send a message via AIM to Chris8sirhC
I'm sure a speaker would benefit more from mounting the drivers on a carbon fiber body than having carbon fiber wrapped around the body. Carbon fiber is extreemly rigid, yet it also takes ALOT of the vibration out of things. This is ideal for a speaker enclosure, or at least a front baffle. For a more tangible explaination, go to your local bike shop, ride a Al. bike, then ride a carbon fiber bike, you will notice a huge difference in ride smoothness, yet it will still have all the stiffness of the Al bike.
Old 10th May 2004, 01:42 AM   #12
baggystevo82 is offline baggystevo82  United Kingdom
baggystevo82's Avatar
Send a message via MSN to baggystevo82
In an oven, yes, to cure the epoxy.
Autoclaves also work under pressure, so they increase the ratio of carbonfibers in the composite. Plenty of epoxy's can be used that cure perfectly happily at room temperature. The main disadvantage is the ratio thing as far as i know.
Steve
Old 10th May 2004, 01:45 AM   #13
Hmmm, never ridden a carbon bike, but from the description steel frames would be even more the other end of the spectrum to carbon. I quite like the springiness of steel frames though.
Maybe laying up carbon for a baffle with the weave in random directions would be a good idea?
Steve
Old 10th May 2004, 10:42 AM   #14
5th element is offline 5th element  United Kingdom
5th element's Avatar
This is indeed true my dad does time trials and races etc on a regular basis and has recently bought a set of carbon fibre front forks to improce the ride.
Hmm what about a dipole panel making that really stiff etc
I was going to make mine finally out of MDF but with goves cut out and trus rods (the things used in guitars to stop the neck breaking under steel strings) placed in the groves. However a carbon fibre panel could easily be made.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 10th May 2004, 11:15 AM   #15
Ahh I see you were on about road bikes now...
Steve
Old 10th May 2004, 03:18 PM   #16
Actually steel provides a smoother ride that Al. Al is usually considered the most harsh, but lighter than steel. Steel and Ti are both considered to be smoother and less harsh, but the Ti bikes are usually as light or lighter than Al ones but much more expensive. And carbon bikes are the smoothest and usually more expensive, but not quite as expensive as Ti. I guess a drawback (depending on who your asking) of Carbon bikes is you can't "feel" the road under you like you can with other bikes.
this is what i race on, except i have the black version
That carbon bi-pole idea sounds great, i would just add some mass to it since carbon fiber is so light weight.
Old 10th May 2004, 03:57 PM   #17
Karoliina is offline Karoliina  Finland
Karoliina's Avatar
How about some aircraft epoxy and composite materials:
http://www.wicksaircraft.com/catalog...d=1/index.html
How do I use carbon fiber + MDF wood + glass fiber to make speaker?Hide this!Advertise here!
carbon fiber to make chassis diymax62 Everything Else 1 19th December 2007 04:13 PM
carbon fiber earing Instruments and Amps 8 13th March 2007 05:04 AM
parts express carbon fiber speaker SQ Kid Multi-Way 4 30th May 2004 12:04 AM
Carbon Fiber be used for speaker material? StylinLP Multi-Way 3 15th January 2003 10:51 PM
CArbon fiber enclosure jouch Multi-Way 1 14th March 2002 10:49 AM
Copyright ©1999-2017 diyAudio
