Dear all,
Please, could you explain something below: First: - I know that impedance of loudspeaker is not constant while they are being used. It rates to audio frequency. But I dont know it rates directly or inversely. - Otherwise, power (Watt) inversely rates to impedance (ex: 8 Ohm ~ 100W; 4 Ohm ~ 200W). => So, I am asking the relationship between audio frequency and power. Second: - Wide audio frequency bandwidth causes wide loudspeaker impedance bandwidth. But speaker manufactors just tell us only one power (ex: 100W @ 8 Ohm). So, how to know the loudspeaker impedance bandwidth. What is the marked power on the loudspeaker? Third: - The relationship of amplifier power (Watt), loudspeaker sensity (dB) and loudspeaker power (Watt). Are there some equation and/or formula of them? Or it is just only human feeling? Thanks for your looking. Regards, Cominup
Ill do it by myself |
#2 |
Speakers sensitivity is rated at dB/2.83V.
For an 8 ohm nominal driver / loudspeaker dB/2.83V = dB/W For an 6 ohm nominal driver / loudspeaker dB/2.83V = dB/1.3W For an 4 ohm nominal driver / loudspeaker dB/2.83V = dB/2W For an 2 ohm nominal driver / loudspeaker dB/2.83V = dB/4W The above are just approximations as real efficiency at each point of the impedance curve is hardly ever considered. |
#3 |
1.
Ohms Law: Volts = Current * Impedance Power = Current^2*Impedance Power = Volts^2/Impedance Power doubles into a halved impedance only if voltage is constant and source impedance = 0. 2. Impedance bandwidth (whatever you mean by that) is unimportant. Impedance only matters in most cases if it is too low or too reactive. The marked power on a speaker is rated by IEC or DIN specifications. THese are a band-limited noise signal that is used to find the thermal (not mechanical) limits of the speaker. Search for "IEC power" or DIN power" in your browser. 3. efficiency = 9.6e-10*Fs^3*Vas/Qes [Vas in liters] sensitivity = 112+10*log10(efficiency) SPL in dB = 10*log10(power) +Sensitivity
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 |
Hi Ron E,
Many thanks for yr help, Cominup
| Electronics Theory question... | stereo.pete | Everything Else | 5 | 15th April 2009 02:03 PM |
| Max SPL theory Question | DougL | Multi-Way | 13 | 18th March 2005 01:57 AM |
| Question on L-pad theory/formula | leadbelly | Multi-Way | 8 | 19th January 2004 05:39 PM |
| CoolMos - ZVT SMPS - theory question | Petter | Parts | 12 | 17th January 2003 01:46 PM |
| Basic loudspeaker theory question | Andrej | Multi-Way | 6 | 28th April 2002 06:53 AM |
| Page generated in 0.08831 seconds (75.16% PHP - 24.84% MySQL) with 10 queries |
