Old 4th May 2004, 07:44 PM   #1
Default Crossover - Three way to Two way...
I have a circuit diagram for a three way crossover that i am going to use for my main speakers. I also want to use the same Bass/Mid and Tweeter drivers for my center channel and so does anyone here have any ideas which components I would need to remove to allow the bass/mid unit to get the full bass ??
NOTE:
i) R3 is just used for simulation for L4
ii) My current guess is just the following components:
C3
R3+L4
Any thoughts ??
Old 5th May 2004, 05:02 AM   #2
Jay is offline Jay  Indonesia
I think the situation is not that simple. You need to post more information. The values will at least help to know the crossover points (L1,C1,L3,C3) as well as the bump to be filtered (R3,C4,L4).
Old 5th May 2004, 10:42 AM   #3
5th element's Avatar
Well I can comment. The trap circuit works in conjunction with c3 to form the highpass. The trap kills the impedance hump at driver resonance.
L3, R2, R4 and C5 are the lowpass filter. Strictly speaking L3 R4 and C5 form the lowpass filter and R2 is there to make everything hunky dory with the rest of the network. You cant just remove components with this to go from three to two way. Plus this is a midrange driver, not a mid/bass so its not going to work even more.
I have emailed you mark about this.
Matt
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Help me with a crossover. raypalmer Multi-Way 4 5th April 2009 01:48 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Crossover help please :) Tenson Multi-Way 17 15th April 2006 09:34 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.07822 seconds (71.98% PHP - 28.02% MySQL) with 11 queries
