Old 4th May 2004, 07:11 PM   #1
Default Calculate BL
Here's a formula for BL from an old thread:
Qes=1/(ws*Cms*Res) and
Cms=Vas/(rho0*c^2 *Sd^2) and
Res=(Bl)^2 / Re
Bl=sqrt((rho0*c^2*Sd^2*Re)/(ws*Vas*Qes))
rho0 = density of air =1.2 kg/m^3
c = velocity of sound = 345 m/s
Sd = Equivalent piston area in m^3
Re = voice coil DC resistance in ohm
ws = 2 *pi * fs
fs = free air resonant frequency of the driver in Hz
Vas = Volume equivalent to the cone suspension
Qes = "electrical" Q value of the driver
and sqrt... meaning the square root of ...
The definition of Sd can't be right, because m^3 is a volume, not an area. What should it be?
Thankee.
Dave
Davy Jones
Old 4th May 2004, 07:52 PM   #2
GM is offline GM  United States
GM's Avatar
m^2, but I use this formula so that I can input Sd in cm^2 and Vas in liters:
BL = SQRT((rho*(c*0.0001)^2*Sd^2*Re)/((2*PI*Fs)*(Vas*0.001)*Qes))
It's nit-picking, but I've found the best correlation with actual measurements is when rho = 1.20997 kg/m^3 and c = 344.424m/sec..
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 4th May 2004, 08:06 PM   #3
Svante is offline Svante  Sweden
Svante's Avatar
Default Re: Calculate BL
[/B]
Yes, sorry, it should have been m^2.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 4th May 2004, 08:08 PM   #4
GM
Ahhhhhh.
BL = 1.1239
Thanks much.
Davy Jones
Old 4th May 2004, 08:48 PM   #5
GM's Avatar
Hmm, I double checked to make sure I didn't copy it wrong from my spreadsheet, so you must have done something wrong since it calcs to 4.5015 using the FE107E published specs, while Fostex lists it at 4.7. The difference being that theirs is calc'd using a different 'p' and 'rho'. You can sim using both to see the subtle difference it makes.
I can't imagine any driver having such a low BL.
GM
Old 4th May 2004, 09:56 PM   #6
GM
When I use 4.5, the ML King spreadsheet graphs look ridiculous. I guess I'm doing something wrong.
Davy Jones
Old 4th May 2004, 10:17 PM   #7
GM's Avatar
Dunno. Since you have a licensed copy, send me your .mcd worksheet and a description of what you're trying to accomplish.
GM
Old 5th May 2004, 05:58 PM   #8
GM
Thanks for the kind offer. I found my mistake, though. I miscalculated the effective cone area. I omitted pi. Doh!
It's looking pretty good now. I tried emailing it to you, but the diyAudio.com email thingy does not have a provision for attachments that I could find.
Here are the goals:
1. Cheap
2. Low enough bass to cross over to a sub at about 100 Hz (or below)
3. Small enough to fit a 15x15 ft office.
I'm actually going to build at least two sets of speakers. Only one set has to be inexpensive. But I'm doing the cheap one first.
A friend is going to build the cabinets. He's keen on using Fostex fe107e's. So be it. The fe107e has a small suckout between 400 and 600 Hz, so I've tried to put the transmission line 3F ripple right on top it.
Here's one design:
So = Sl = 30 in^2
L = 43 in
driver at 10"
0.75 lb/ft^3 stuffing top to bottom
Davy Jones
Old 6th May 2004, 02:05 AM   #9
GM's Avatar
Hmm, I didn't check, just assumed you could. Anyhoo, your pipe is way too big/overstuffed. The only way to get solid/smooth output to 100Hz is in a ML-TL, though you won't be able to design in a 500-600Hz hump in the response. Of course you'll still need some BSC if not nearfield.
Max flat using published specs:
rp = 0.5"
Lp = 0.75"
density = 0.2lbs/ft^3
L (in)
15.38
S0/SL (in^2)
21.366
driver (in)
6.302
Vb(ft^3)
0.19
Fs or Fb (Hz)
83.9
GM
Old 6th May 2004, 02:50 AM   #10
...etc
Dang! How did you do that?
Davy Jones
is it correct to calculate OTL? sam8888ysl Tubes / Valves 15 26th November 2007 05:48 AM
How to calculate the BL of driver p_eric Subwoofers 21 3rd November 2006 11:52 AM
Calculate SPL exuviae Subwoofers 3 5th July 2006 07:51 AM
help ! how to calculate?????????? bogdan_borko Solid State 3 18th January 2006 10:15 PM
Calculate BL? Dave Jones Multi-Way 3 4th May 2004 08:04 PM
Page generated in 0.10825 seconds (83.25% PHP - 16.75% MySQL) with 11 queries
