Old 4th May 2004, 06:46 PM   #1
rwagter's Avatar
Default woofer in 11 liter (0.38 cu ft)
So I have as a study project build these enclosures:
Their inside volume is approx. 11 liters . I had in mind using hds182 woofers. When calculating in unibox I concluded that this would not be the best speaker since portnoise will be extreme and Xmax is exceeded under 100Hz.
The big question now is what woofer will have an fb ~ 55 Hz and can be placed in a 11 lietr encloser (bass-reflexed or closed)
Or will I get more result with placing a passive radiator in the bottom?
Ralph
ps budget is important otherwise I'd use a scan speak 15w/18w
Old 4th May 2004, 07:09 PM   #2
Could do a lot worse than installing this :
http://home.hetnet.nl/~geenius/DD8-MkII.html
Though volume may be less than 11 litres due to the drivers
crossovers etc. Sealed is perfect for a subwoofer, full range
drop the tuning a little to say 37 Hz due to smaller volume.
sreten.
Old 4th May 2004, 07:57 PM   #3
markp is offline markp  United States
Take a look at Hi-Vi F6 driver. I just go one to play with and it sounds great so far and will work in a box around 11l-12l.
If it sounds good... it is good!
Old 4th May 2004, 08:12 PM   #4
In this application you have to use drivers of the 13-15 cm range
Vifa PL14
Peerless HDS 134
Visaton AL130
Seas new alu range
Audax HM130Z16 or G8 I don't think it will reach 55 Hz
are the more affordable types
When is a liter not a liter? The shape of things to come. brucegseidner Full Range 2 27th June 2009 02:35 AM
Random 12" woofer in 100 liter cabinet Klimon Subwoofers 4 20th December 2006 03:16 PM
Fostex 126e response (10,5 liter BR) Juspur Full Range 0 2nd February 2005 07:18 PM
DIY speakers using 32-liter cabinets smurfette Multi-Way 17 2nd March 2004 03:11 PM
1000 liter sub jmiyake Subwoofers 12 26th April 2002 05:50 PM
Page generated in 0.08846 seconds (74.44% PHP - 25.56% MySQL) with 10 queries
