Old 4th May 2004, 07:40 AM   #1
mikee12345's Avatar
Default 350w plate amp,whats this wire!
hey all
just got a 2nd hand plate amp
Firstly=the output seems unfiltered
secondly-the output is quiet
using a 2226 with 20w i know how loud my jbl can go,so im not really sure whats up
what are these wires,they look FAT and like suspiciously like something i need!!!!
its connected near the output transistors, speaker out connectors?
am i just hearing line level stuff ?
Help!
next time i might just buy it fullprice from jaycar to avoid the online auction hassle.....
at first i thoht perhaps that my Sources speaker outputs were not BLACK (-ve) earth based,because i thoht perhaps i was hearing the tiny flow through there so i switched that, and the output was still the same! (ofcourse i risked the first amp to test this but it seems to work still)
yes i can model horns and ported boxes,but this is just annoying!
Old 4th May 2004, 07:49 AM   #2
mikee12345's Avatar
+ its night time and our lights seem to be less than 100w so its hard to see minute details on the boards...
Old 4th May 2004, 08:01 AM   #3
hi
thats the positive supply
form the power supply to the out put transistors
this is some thing you can do about it
measure the voltage on the power supply - at the bridge rectifier
- follow the - ve and + ve lines from it - see where the - ve wire goes
it should most probaly run to the out put transistors - opposite to wher the red wire is connected to the out put board
if so trace out how the - ve is connected to the power supply - points (near the rectifier)
now measure the voltages - of the - ve terminals with respect to earth - measure at the rectfier point and the out - put transistor board
then measure the + ve terminals - if you find the +ve voltage not reaching the out put transistors
connect the red wire similarly as they have connected the - ve (black wire to the supply)
protection
place a 500 ma fuse on the red wire line - that way any wrong connection or shorts will not damage any component
suranjan
Old 4th May 2004, 08:08 AM   #4
mikee12345's Avatar
Thanks,i cant find my meter though its in storage !,surely theres a VERY obvious connector someplace!
Cheers
Old 4th May 2004, 08:10 AM   #5
djQUAN is online now djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
if the black wire goes to the filter cap's center tap, and the red wire connects to all those ceramic resistors, then it's the speaker output.
Old 4th May 2004, 08:35 AM   #6
mikee12345's Avatar
hah,some one i know thinks it COULD be the sub out
note,on the front it doesnt actualy SAY 'sub out' it says 'high level in,out' and line in and out....
infact im beginning to think it is the SUB OUT ,because the amp is meant for mounting on the box,il double check when i find my meter,il have to go search and see if its in a box at a relatives house.
+40v Dc on the old jbl mite wake it up abit !
just thoht some one would know outright
Old 4th May 2004, 08:49 AM   #7
hi
if ure 2226 is performing low - then most probably the - ve supply is connected and what u are getting is a half signal out put at the spk lines - there fore the spk is playing a bit low
as for a sub out - it will be a line level out - then the wire should be a screen cable (with the earth shielding) and it wont be such a heavy duty guage wire like the one that is disconnected
yet the best would be to actually check the voltages ,
also the sub out will never run from the out put tranny board - it will run from the input control circuitry board from a small ic - op amp ,
yet its best that you take all precautions , please insert a fuse (mentioned before)
at my end i am not only a transducer design engineer - i have designed a lot of these plate amps (i do audio pcb designing too)
for my customers who use my drivers - and end up asking me to improve their amps ets
you can run a back up check on me - search for hunter audio in the - solid state section ,
suranjan
Old 4th May 2004, 08:50 AM   #8
mikee12345's Avatar
i actualy cant tell where any of the tracks are,i cant remove the pcb easily , and the blops of black goop cover up where exactly the wires go....
Cheers!
Old 4th May 2004, 08:53 AM   #9
hi
man - one sec do you have - 1 red wire that is not connected or
2 wires that is not connected
intially you mentioned there is 1 (red)
if they are two and (the red ) runs to the emitter resitors on the out put tranny board - and not to the output transistors itself
and the black wire you are showing now runs to the filter caps
then this is the speaker out wire
suranjan
Old 4th May 2004, 08:54 AM   #10
the connector is a slide "quick disconnect" often used to connect to speaker terminals.
350W Power Amp with LM3886'S zafira1981 Chip Amps 44 2nd February 2008 06:00 AM
FS: (AU) 350w Jaycar subwoofer plate amp w/ remote fishball79 Swap Meet 0 16th November 2004 04:32 AM
Whats the voltage rating on this wire? lgreen Parts 3 20th October 2004 09:08 PM
Whats the deal with magnet wire? PaulHilgeman Parts 17 5th March 2003 12:11 AM
Need 250 to 350W into 4R djnigma Solid State 7 18th September 2002 03:14 PM
Page generated in 0.10964 seconds (83.78% PHP - 16.22% MySQL) with 11 queries
