low frequency L pad
low frequency L pad
Old 3rd May 2004, 11:21 PM   #1
brumil is offline brumil  United States
Default low frequency L pad
Hello all,
I am brand new here. I am designing a x-over network and am using 2 woofers in parallel configuration. My LF impedence drops to 2.09 ohms @ 20hz. I believe my Rotel power amp might not enjoy this. I want to add an L pad to the woofers. I know I need large power handling resistors. Is using a LF L pad sonically acceptable? I know I could run them in series, but I know THAT is not.
Help!
Old 4th May 2004, 01:24 AM   #2
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Wiring woofers in series is acceptable. Padding woofers is not.
Old 4th May 2004, 01:14 PM   #3
Guess I had it backwards after all. Thanks Bill!
Bye the way, Iv'e never heard a chicken sneeze, but I have heard a dog fart.
Old 4th May 2004, 03:07 PM   #4
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
I understand that wiring a single woofer with dual voice coils in series makes a sonic difference because Le increases by a factor of 4 vs parallel. Why wouldn't series vs parallel connection for 2 woofers have the same effect?
Also, please explain why padding a woofer is bad other than wasting power. I did this on a pair of speakers for someone who listens to classical music but he wanted more bass for LFE's in his HT and for when his son listens to his type of music without adding a sub. An Lpad is on the tweeters as well. I had to do it this way because the Lpad wouldn't work right on the mids because they are an array wired with a higher impedance. I tried alot of different wiring combinations and this way gave the best sound balance and a highly adjustable speaker. With both Lpads set to minimum it's a little heavy on the bass and treble (the way his son likes). It's not a high power application and the Lpad on the woofer has held up so far. Did I do something wrong?
Everyone has a photographic memory. It's just that most are out of film.
Old 4th May 2004, 05:19 PM   #5
Jay is offline Jay  Indonesia
Banned
Why should it be wrong? I did the same thing with low powered amplifier and a bookshelf sized speaker and my friends like it a lot. But I guessed that would be fatiguing.
low frequency L padHide this!Advertise here!
ESL low frequency rolloff SkySeeker Planars & Exotics 31 15th February 2008 08:50 AM
mhz switching frequency lumanauw Class D 40 24th December 2007 02:48 PM
Frequency CUT and a HOLE in frequency range... -_nando-_ Everything Else 0 28th December 2005 09:17 PM
1st Order XO with -6dB XO frequency. Has anyone tried this? primalsea Multi-Way 20 28th May 2004 07:10 AM
What's my x-over frequency? hanskrj Multi-Way 0 5th February 2004 08:20 AM
Copyright ©1999-2017 diyAudio
