Old 3rd May 2004, 07:09 PM   #1
ble0t is offline ble0t  United States
ble0t's Avatar
Default Speaker Workshop - Microphone?
I am almost done with my jig for use with Speaker Workshop, and I realized I'm missing something rather important....namely a mic and a preamp to test with. Seeing as how I'm new to this DIY game, does anyone have any recommendations on a reasonable mic and mic preamp that would work well for capturing and doing analysis? Any help would be much appreciated.
gravity always wins
Old 3rd May 2004, 07:26 PM   #2
tiroth is offline tiroth  United States
Preamp: Behringer UB802 $50-60
Mike: Behringer ECM8000 $40
Old 3rd May 2004, 08:08 PM   #3
what about the radio shack spl meter?? it has an rca jack output...would this be suitable??
Old 3rd May 2004, 08:15 PM   #4
not flat enough. you can also build your own mike and preamp using a capsule, if you want to lower the cost.
Old 3rd May 2004, 09:27 PM   #5
ble0t's Avatar
Before I order, would there be any reason I wouldn't want to drop down to the UB502 preamp if I wanted to save a couple bucks? I don't see myself doing anything in the near future that would require more than the one mic input.
gravity always wins
Old 3rd May 2004, 09:41 PM   #6
bzdang is offline bzdang  Canada
bzdang's Avatar
Yes, buy something. I put together a preamp from plans but made a mistake somewhere so it doesn't work. I will get an electronics friend to fix it but it will cost me some beer. I would have been way ahead if I had just bought a preamp and mic.
Benford's law of controversy - Passion is inversely proportional to the amount of real information available.
Old 3rd May 2004, 09:53 PM   #7
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default about the RS
I use this RS spl meter but I have to say that it is a pain to calibrate. They vary from sample to sample. I had problems with its bass behaviour (everybody elses was undereading, mine was overeading) had to put it against a calibrated panasonic to make the compensation file, then I changed the caps inside and it came to balance, then I wrote another file....
If you dont already have it opt for the Behringer.
Old 3rd May 2004, 10:50 PM   #8
Ron E is offline Ron E  United States
Ron E's Avatar
I built a wallin preamp. I probably messed it up somehow, but it functions poorly and has little gain and sounds like it is clipping. I wasted $30 in parts and about 6-7 hours of my time in shopping for the parts and building the circuit. I have no Oscope, so I can't tell where the problem is and I don't feel like swapping component after component until I find the problem.
The Behringer units go for less than retail, even at guitar center, where I bought mine. I bought the UB-802 ($40) and ECM-8000 ($35), and a 15 foot mic cord ($10), for that price, I don't know why I wasted my time on the wallin preamp. It would cost me well over $100 in parts to duplicate the UB-802. I'll never build another audio circuit again, except for one-off measurement instrument circuits.
The UB-502 won't work because it doesn't have phantom power.
Don't waste time with the RS meter, mine has a lot of hum pickup and is really nonflat - like +8/-15 from 2kHz to 20kHz... I posted a comparison of the RS meter and my Behringer mic - do a search.
The Behringer mic is reasonably flat - about +/- 1dB. If you need better than that, you can send it to Kim Girardin and get an individual cal file for about $40.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 3rd May 2004, 11:25 PM   #9
Pedja is offline Pedja  Serbia
No offence meant to anyone who in the good will have contributed own work, but most known stuffs in this domain that can be found online are needlessly complicated and, again no offence meant, to most speaker builders, are a nightmare. I mean here on the jigs, preamps, tutorials how to build microphone from Panasonic capsule…
If you choose to DIY this, do yourself a favor, do not build pointless jigs, SpeakerWorkshop tutorial will tell you all you need to measure impedance and passive components is one resistor. Do not build unnecessarily complicated preamp intended to ape industrial units, all you need like preamp is one operational amplifier set to gain of 20-30 and battery. And one pencil in which you will put a capsule. Costs will depend on what you already have, but you should be able to accomplish this for $10-15. Then you are done and can deal with measurements.
Pedja
Old 4th May 2004, 04:19 AM   #10
Originally posted by Pedja
(...) SpeakerWorkshop tutorial will tell you (...)
Sorry, I meant SW’s Help (chapter Cables and Connectors).
Speaker workshop ? A_Reef_Scene Multi-Way 14 28th February 2007 12:39 AM
Speaker Workshop MMadrid Multi-Way 0 25th June 2006 07:49 AM
Which mic for speaker workshop? azira Multi-Way 2 12th February 2004 05:12 PM
Speaker Workshop + Microphone = invaluable wintermute Multi-Way 26 5th December 2003 04:14 PM
Page generated in 0.10803 seconds (75.84% PHP - 24.16% MySQL) with 10 queries
