very low Q woofer
Bringing things back on topic, a Q=0.5 highpass acoustical response is critically damped. Lower Q is overdamped. Higher Q is underdamped -- it will ring. SL uses a low Q woofer in a slightly overdamped enclosure but he uses EQ to shift the acoustical response to Q=0.5 at 20 Hz which is critically damped. It doesn't matter much how you get there -- driver + box + EQ. All that matters is the final acoustical response of the whole system.
Always hard to compare 'because all things are never equal',
but given the choice between two woofers (bass for a 3way, sealed cabinet)
1. Qts 0.2, Le 2.4
2. Qts 0.4, Le of 1.4
Which would you go for? The lower Q or the lower Le?
1. Qts 0.2, Le 2.4
I'd never buy a driver based on those 2 specs alone unless it was a super cheap one. Please provide more info, but a Qts of .4 requires a box that's over 6 times bigger. Also, if you're going without a sub and you have a nice wide range mid, then you could restrict your woofer to the low stuff and get away with the kind of woofers with the higher Le's.
When one is considering ultimate damping in such detail,one should also consider if the relevant driver has enough Vd to cope with SPLs required.
Personaly i aim for low distortion also
-id get a woofer with shorting rings and low distortion efforts..rather than an everyday 'average' price woofer.
eg: peerless xls 12" etc
Cheers!
