Old 2nd May 2004, 10:33 AM   #1
maya1 is offline maya1  Italy
Default adjustable resistor or potentiometer choise to use in a crossover
Hi
I'm searching good adjustable resistor or potentiometer with a value range of 5-10 ohm to use at the end of signal path that go to a tweeter (Audax TW034 X0).
Old 2nd May 2004, 02:41 PM   #2
Try using a 15R to 20R connected as an L-pad, has many advantages.
Or a lower value with additional series resistors both ends
if you'd like very fine resolution over a more limited range.
sreten.
bias supply question / sanity check - adjustable resistor? ilted Planars & Exotics 0 5th May 2009 02:12 PM
electronic adjustable resistor luka Everything Else 20 2nd August 2006 12:04 PM
How do you make an audio potentiometer into a variable resistor? Darren Nemeth Parts 1 10th February 2005 07:15 AM
adjustable crossover rv1890 Multi-Way 2 11th January 2005 10:03 PM
Potentiometer VS variable resistor for level adjusting Bricolo Everything Else 5 1st March 2003 01:31 AM
Page generated in 0.07112 seconds (66.28% PHP - 33.72% MySQL) with 10 queries
