Richard Allan speakers.  T-S parameters attached.
Old 30th April 2004, 01:02 PM   #1
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Default Richard Allan speakers. T-S parameters attached.
T-S parameters of many of the old, but well-respected Richard Allan drive units.
Data just received from RA themselves.
Old 1st May 2004, 06:24 AM   #2
Jonathan Bright is offline Jonathan Bright  Australia
Dear Ouroboros, Thanks, very thoughtful. I own an HP12B 1979 vintage (not sure which Res. Fq. yet) It is going in a sub one day. I needed those specs. Jonathan Bright.
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 23rd September 2005, 12:41 PM   #3
quasi is offline quasi  Australia
quasi's Avatar
Default Richard Allan Atlas 15
Hi Ouroboros
I have been given a Richard Allan Atlas 15 so your specs are really useful. Do you have any information about it's power handling?
Quasi
Old 23rd September 2005, 04:13 PM   #4
I had a R.A. Pavane way back in '71/2. It was a 3way with a power handling for the whole including crossover of 25w from memory.
The CG12 in there would I guess handle about 15w (or maybe it was 12.5w) but it was very efficient. When replaced with Tannoy HPD385 (94db/w) in 100litre cabs the Pavane needed less voltage than the Tannoy for the same volume.
In those days manufacturers had only just started going down the route of using power to replace air inside the cabinet. Only recently have they started re-inventing the wheel to get impact and livelyness back into speakers.
regards Andrew T.
Old 20th January 2008, 08:30 AM   #5
googlyone is offline googlyone  Australia
OK, this is a few years out of date, but I guess it is worth adding a snippet ehre...
The Richard Allan ATLAS speakers were quite high power for their time. The ATLAS-15 was the big brother of the HD-15. The HD-15 was 125Watts "RMS". The HD-15 used a 2 inch voice coil, and with music driven at these levels is a reliable driver.
The appilcation of the HD and ATLAS series was for PA use, though these drivers are of excellent quality, and more than applicable for hifi use. They have a surprisingly flat frequency response and low distortion even to fairly high levels.
Old 18th May 2013, 05:38 PM   #6
John Cory is offline John Cory  South Africa
Hi There.
Anyone out there have any idea what the data / Thiele-Smalls are for a Richard Allan CG12 TC? I've "inherited" a pair and I'd like to build suitable cabs for them.
Regards.
The Sound Man
Old 25th May 2013, 05:16 AM   #7
I used to have a pair of Richard Allan CG-12 drivers. I would imagine they will be very similar to the one with the whizzer.
Fs: 32Hz
Vas: 257 Litres
Qt: 0.425
Qm: 10.1
Qe: 0.44
Le: 0.53mH
Re: 7.46 Ohms
Sd: 490 cm2
These were best in a fairly decent sized vented enclosure. They were absolutely excellent drivers, and had a very well behaved frequency response.
Phil
Old 26th May 2013, 06:51 PM   #8
Thanks Googlyone.
Plugged the data into my faithful design program and hey presto! a 250 litre box appears. bloody big?? Anyone know where I can get plywood cheap?
Regards.
The Sound Man
Ps.
Anyone know the upper frequency limit of this speaker?
Old 30th May 2013, 09:35 PM   #9
You will be able to get away with a much smaller box than that - but dont expect a petite little 20 litre box - these are honest to god fold fashioned drivers... Big vented boxes a go-go.
I reckon those drivers used to be in a box of about 150litres or so - they were big but not crazy. I do not have the actual box dimensions as rather unusually for myself I reused the original boxes.
I do recommend that you measure the T&S parameters yourself. Tricks to this are:
- Measure Re as accurately as you can - the remaining parameters are very sensitive to errors in this
- If you have a sound card based measurement system, use Audua using the aded mass method, or
- If you dont have a sound card measurement system, use an oscillator, multimeter and closed box method. There are online tools that will walk you through this.
One thing that your model should have shown is that you can expect some surprisingly good low end performance from the drivers.
On measuring their frequency response I also found that their response out to quite a high frequency (kilohertz region) was very good indeed.
Have fun!
Old 31st May 2013, 01:36 AM   #10
radiosmuck is offline radiosmuck  Canada
radiosmuck's Avatar
Originally Posted by John Cory View Post
Hi There.
Regards.
The Sound Man
I can get you the internal measurements of a box that contained a Richard Allen CG-12, could be a Parvane.
Richard Allan speakers.  T-S parameters attached.Hide this!Advertise here!
Richard Allan HP 12B ClaudioB Multi-Way 19 26th March 2010 01:08 PM
Richard Allan Maramba Speakers opm33 Multi-Way 1 29th June 2009 10:52 PM
Richard Allan CG8 aquapiranha Full Range 4 25th June 2009 05:50 AM
Richard Allan X-over values Jonathan Bright Multi-Way 0 12th July 2008 08:13 AM
Please Help ? Richard Allan LP8B !! papanohn Multi-Way 1 29th July 2006 07:46 PM
Copyright ©1999-2017 diyAudio
