I was wanting to build a small, low power (50-100 watt) bass horn using an 6 1/2, 8, or 10 inch sub. This will be used for my computer sub, and as an experiment in horn loading drivers. Any help would be nice, Driver recommendations, documented projects, anything. Thanks.
#2 |
Banned
i would say "Small bass Horn " is an oxymoron.
#3 |
I'm with Till. The driver may be small, but the size of the horn is still determined by the wavelength of frequency at cut off.
That is to say, a 40 Hz wavelength is about 28 ft. If you figure 1/4 wavelength for the horn with corner loading, you still end up with 7 ft of ever-expanding length wrapped up (folded) into a box which must have a mouth circumference to fit the same frequency/wavelength (some fudging here). So, while the driver may be small, the box is not. Might do a search on the recent thread here about the "Bose Cannon". Similar 1/4 wavelength concept again without the horn expansion. Or use a transmission line and add power. Tim |
#4 |
by small, i mean, a reasonable size folded horn. I dont want something 12 feet tall and 6 feet wide. Just something small.
#5 |
2 Tang band W8-740c . Properly loaded into a corner. Your long skinny horn could be ~1/2 Lab horn size. For a 30 Hz horn.
#6 |
1) define small
2) state SPL needed look at my site for an 8" design i used which is ~150litres. www.geocities.com/basshornguy |
#7 |
Speakerholic
How 'bout a 1/2 size A7 with an 8"
Cal |
#8 |
I just so happen to have 2 W8-740c's. Anyone have box designs?
#9 | |
http://www.users.bigpond.com/dmcbean/ |
#10 |
Hi bhg,
Here is my contribution, I hope this can help. |
| Which (small?) bass horn for Coral 12-inchers? | atilsley | Subwoofers | 5 | 10th June 2009 08:02 AM |
| how to go from horn response to a folded bass horn design? | paulspencer | Subwoofers | 8 | 4th November 2005 10:44 PM |
| Comments on bass horn sim in horn response | paulspencer | Subwoofers | 38 | 1st November 2005 08:34 PM |
| looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P | SkinnyBoy | Multi-Way | 24 | 13th February 2004 05:06 AM |
| Page generated in 0.10290 seconds (74.23% PHP - 25.77% MySQL) with 11 queries |
