Would 3 or 4 beanbags stuffed with the small polystyrene pieces stacked in a corner make an effective bass trap? If some air space is mandatory maybe add some mylar balloons glued closed in the center (of course that would render them useless for sitting on).
Everyone has a photographic memory. It's just that most are out of film. |
#2 |
If the PS beans are open cell foam and the bag is acoustically transparent, I bet it will absorb nicely in the midbass, at least as well as a good-sized St. Bernard.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
It could work.
I once made a similar experiment to reduce the reflections from the rear wall. I piled up a whole lot of textile (as in clothe, towels, sheets...you name it, it was there). It worked well till my wife came home. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
| Cylindrical Bass Traps | lgreen | Multi-Way | 4 | 15th August 2007 12:01 AM |
| Made me some bass traps and an amp stand | lgreen | Multi-Way | 5 | 11th June 2007 03:23 PM |
| DBA (dual bass arrays) and active bass traps | capslock | Subwoofers | 3 | 20th August 2006 12:52 PM |
| bass traps? | bostonswoop | Subwoofers | 3 | 30th March 2006 02:03 PM |
| traps in to3 construction | lowlevel | Solid State | 9 | 5th January 2005 08:14 PM |
| Page generated in 0.07179 seconds (64.12% PHP - 35.88% MySQL) with 10 queries |
