Old 28th April 2004, 07:29 PM   #1
Default Standing wave in a bass cabinet
I work on a new speaker design and would like to avoid standing wave problem (as much as possible) on the bass section of the cabinet.
The bass section of the cabinet have a special shape :
10.5" W x 10.5" H x 17.25" D at the bottom and then
6.5" W x 14" H x 17.25" D
Just like a stove with a chimney
The x-over point is 350Hz and the upper part would be fill with fiberglass as well as a part of the bottom.
What do you think
Daniel
Old 29th April 2004, 05:23 AM   #2
Svante is offline Svante  Sweden
Svante's Avatar
If it is a closed box, filling it with fiberglass is a good way of avoiding standing waves. If it is a bass-reflex, you should not have as much stuffing, but it will probably be OK anyway.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 29th April 2004, 11:10 AM   #3
Hi Svante,
It's a closed box. You confirmed what I was thinking. With the x-over point, standing wave should not be a big problem in this box + fiberglass will do the rest of the job.
Thanks for your answer !
Daniel
Old 30th April 2004, 05:44 AM   #4
coolkhoa's Avatar
Send a message via AIM to coolkhoa Send a message via MSN to coolkhoa Send a message via Yahoo to coolkhoa
Hmmm...I think you should be fine as long as you line the cabinet walls with dampening material and stuff it loosely, like what Svante has said. The golden ratio doesn't really apply in this situation, unfortunately. I'm afraid this is as much as I can help you.
Good luck.
KTK. Kool To the Kore.
Floor standing cabinet for FE207e+FT17H ? nina Full Range 28 11th October 2007 09:29 AM
Planar bass wave to take care of room modes ?? JinMTVT Subwoofers 12 4th October 2007 05:15 PM
Bass Cabinet - little help here bassampnewb Instruments and Amps 21 29th December 2005 10:58 PM
Bass shaker attached to a free-standing board. Circlotron Multi-Way 5 19th March 2003 01:15 AM
Removing internal standing waves from speaker cabinet Bedroc Multi-Way 7 27th March 2002 10:34 PM
Page generated in 0.07136 seconds (79.00% PHP - 21.00% MySQL) with 10 queries
