Old 28th April 2004, 12:04 PM   #1
Svante is offline Svante  Sweden
Svante's Avatar
Default Audax Sd value
Does anyone know where to find Sd values for Audax speakers?
In particular I am interested in HM130Z12.
Also, does anyone know if the "phase plug" moves with the cone or if it is fixed?
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 28th April 2004, 12:11 PM   #2
Did it Himself
richie00boy's Avatar
Can you find a Pd value? This is just the diameter, so Sd (which is area) can be found by pi * [(Pd/2) * (Pd/2)]. Remember to convert the Pd units into what your target Sd units should be first.
Old 28th April 2004, 12:19 PM   #3
tiroth is offline tiroth  United States
I think a good Sd figure can't be geometrically calculated since it depends in part in the flexion of the surround and the edges of the cone.
The phase plug is fixed.
Old 28th April 2004, 01:49 PM   #4
Ron E is offline Ron E  United States
Ron E's Avatar
If the use for the spec is noncritical, I'd just say it has a 10cm diameter and subtract the 2.5cm plug area from that. For most modeling purposes, this is good enough. So much so that if you want better, it would be best to just buy one and measure it yourself.
Geometrically, it makes sense to use half the surround when measuring Sd. The cone should move as a piston until several octaves above resonance, so talk of flexion at low frequencies is nonsense.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 28th April 2004, 02:58 PM   #5
5th element's Avatar
Sd for the HM130Z0 is 80cm2, Z12 is 81, google! u find it out.!
Oh the phase plugs are fixed like Seas excel.
Matt
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 28th April 2004, 03:09 PM   #6
Svante's Avatar
Thank you all. I arrived at 84 cm2 from measuring on the front view (counting pixels) on the image below. So 80 or 81 seems good considering that the plug does not move.
Isn't it amazing that Audax doesn't include a Sd number in the data sheet, or at least a diameter figure?
Old 28th April 2004, 10:46 PM   #7
Ron E's Avatar
Looks like 78cm^2 to me.
Sd=pi*(Do^2-Di^2)/4
Audax DIM Multi-Way 11 9th March 2006 08:34 PM
2-way audax bhg41088 Multi-Way 1 23rd July 2004 04:38 AM
Diy Audax sma Multi-Way 13 12th February 2004 06:44 AM
son audax sma Multi-Way 0 27th December 2003 11:40 AM
Audax HT xr628 Multi-Way 1 16th January 2002 07:42 PM
Page generated in 0.08979 seconds (73.91% PHP - 26.09% MySQL) with 11 queries
