I am interested to know the theory explaining/predicting of phase plugs, more especially along the lines of Turbosound TMS-3/TMS-4 midrange section - http://www.turbosound.com/pdfs/tms3.pdf, or other similar or better setup.
Help anyone ?. Thanks and regards, Eric. |
#2 |
Interesting design, thanks for the link.
I can't help you with the science of phase plugs (though, like you, I'd love to learn). However, I'll share a few points on the philosophy behind them. First of all, there appears to be no strict definition of what a phase plug is. I've seen widgets suspended in front of compression diaphragms, mounted on the pole pieces of cone drivers (piercing the cone), suspended in front of cones and occluding the center of dome tweeters (to roll of ultrasonic breakup)--all called phase plugs. Originally, I believe phase plugs were so named because they can be used to alter phase relationships in the passband. AFAIK, they accomplish this by physically diverting the paths of higher frequencies. In this capacity, they are also useful as waveguides. Look at the nice wide polar response plots of those TurboMid drivers. I suspect the phase plug has something to do with that. Also, phase plugs can physically constrain the space over a diaphragm, thus horn-loading certain portions of it, such as those that create the higher frequencies. That's what I was trying to do in the design I present in this thread. DIY transducers--the final frontier Bill |
#3 |
Wgeiger posted these on the high-efficiency speaker asylum:
[013] Title: Phase Plug Modeling and Analysis: Circumferential Versus Radial Types Author: Clifford A. Henricksen Publication: AES-P, No. 1140, Cnv. 55 (1976-10) URL: http://www.aes.org/publications/preprints/search.html Abstract: Mechanical modeling of a simple phase plug yields an electrical-mobility equivalent circuit; a single-frequency notch filter. This applies directly to "normal" circumferential-slit configurations. The analysis is then applied to a radial-slit phase plug, [014] Title: Phase Plug Modeling and Analysis: Radial Versus Circumferential Types Author: Clifford A. Henricksen Publication: AES-P, No. 1328, Cnv. 59 ( 1978-02) URL: http://www.aes.org/publications/preprints/search.html Abstract: Mechanical modeling of a simple two-dimensional phase plug and diaphragm yields an electrical mobility equivalent circuit; a two-pole, low-pass filter. At higher frequencies, this analysis becomes incomplete, and a model presented by Merhaut (1975) is us [015] Title: An Application of Bob Smith's Phasing Plug Author: F. M. Murray Publication: AES-P, No. 1384, Cnv. 61 (1978-11) URL: http://www.aes.org/publications/preprints/search.html Abstract: The war of the phasing plugs still rages after more than 25 years. Compression driver phasing plugs have vacillated between annular rings, salt shakers, teardrops, and now radial slots again. When Bob Smith provided simple design criteria for [016] Title: The Dual Coil Inductively Coupled Loudspeaker System Performance Optimization and the Application of an Acoustic Phase Correction Plug Author: Boaz Elieli Publication: AES-P, No. 2780, Cnv. 86 ( 1989-03) URL: http://www.aes.org/publications/preprints/search.html Abstract: Analysis of the dual coil inductively coupled loudspeaker system using an electrical equivalent circuit is presented, and some of the practical design aspects relating to the system optimization are discussed. The application of an acoustic phase correct [017] Title: Ultimate Performance of Wide-Range High-Frequency Compression Drivers Author: Clifford A. Henricksen Publication: AES-J, Vol. 24, No. 8, Pg. 639 (1976) Publication: AES-P, No.1126, Cnv. 54, (May-1976) URL: http://www.aes.org/journal/search.html Abstract: Performance equations are developed from an electric mobility model of a typical electromagnetic compression driver. The analysis is independent of impedance and relates ultimate performance to material, air, and phase-plug variables. [018] Title: An Investigation of the Air Chamber of Horn Type Loudspeakers Author: Bob H. Smith Publication: ASA-J, Vol. 25, No. 2, Pg. 305-312, Mar-1953 URL: none Abstract: The front air chamber design is treated as a boundary value problem which yields a solution of the wave equation for the general case in which the horn throat enters the air chamber in a circumferentially symmetrical manner. [019] Title: Tweeter Design Considerations Author: George W. Sioles Publication: AES-J, Vol. 4 No. 3 (Jul-1956) URL: http://www.aes.org/journal/search.html Abstract: Constructional and Design characteristics of various types of tweeters are presented. The fundemental design problems of a moving coil, horn loaded transducers are addressed and include: air-chamber requirements, magnet and gap design, and horn characteristics. |
#4 |
Account Disabled
Now if AES would only provide the data freely, as they rightly should....
-Chris |
#5 |
Hello Bill F. and thankyou for going to the trouble to post the links for us all.
However I have to agree with CHRIS8 regarding cost of such information. ![]() Moreso I am asking for FREE information on the subject. Thanks and regards, Eric. |
| Phase Plug, how does it works? | Antonio | Multi-Way | 5 | 17th June 2009 12:05 PM |
| DIY phase plug, snug fit or not? | jamesdb | Full Range | 2 | 20th June 2007 08:34 PM |
| making a phase plug? | nerd of nerds | Multi-Way | 27 | 25th April 2007 03:25 PM |
| Phase Plug Dims ? | valveitude | Full Range | 0 | 16th November 2006 03:10 PM |
| Anywhere to buy off-the shelf phase plug? | bcherry | Full Range | 6 | 19th October 2005 07:22 AM |
| Page generated in 0.12136 seconds (73.01% PHP - 26.99% MySQL) with 10 queries |
