Old 26th April 2004, 04:52 PM   #1
bwaarp is offline bwaarp  United Kingdom
Default custom crossovers
hi there, i'm a definate noob, i've recently got hold of a mach audio m153 (discontinued) its got a 15" driver, a 6"celestion truvox 061mr(8 ohm 50w) and 2 vifa h26tg-0506 softdome tweeters (100w each 6 ohm) the 15" has been replaced with a shitty skytronic 300w , i was wondering iif anyone had any idea as to the best crossover frequencies and slopes for this set up. the cab has a crossover int, but it seems like the mid is getting too much power at the moment and im sure that it could be mde to sound better. whilst im at it any suggestions for a replacement 15" to goin there?
some links:
http://professional.celestion.com/pr...etail.asp?ID=2
http://www.d-s-t.com/vifa/index.htm
any helpappreciated, im hpefully going to attempt to build myfirst crossover..
Old 26th April 2004, 06:13 PM   #2
Your best probable course of action is to leave the crossover
as it is and fit a decent 15" as near to the original as possible.
sreten.
Old 26th April 2004, 06:21 PM   #3
i'm going to replace the 15", but the crossover appears to be a very cheap looking aftermarket one, im not convinced that its right for this setup, hence why i was looking at replacing it
crossovers tonysherwin Multi-Way 3 18th May 2008 12:30 AM
My custom sub box audiobahnkid592 Car Audio 4 13th March 2007 04:19 PM
2.5-way crossovers sriegel Multi-Way 2 30th April 2002 05:47 AM
crossovers grim Multi-Way 3 22nd February 2001 01:52 AM
Page generated in 0.07525 seconds (72.53% PHP - 27.47% MySQL) with 10 queries
