Old 26th April 2004, 01:08 AM   #1
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
Default active corssover, 2 - 3 way or something else?
hey guys,
i'm currently working on an active xover to drive my old b&w 220's actively. Problem is that they are sort of 2.5 way speakers.
First xover is 24dB @ 3kHz, second is 6db @ 1kHz. What should i do?
Should i just build a 2 way linkwitz @ 3kHz and let the speaker's internal (crappy) passive filter do the rest? Sort of defeats the point of biamping since the crossover point is fairly high.
Or should I build a mixture of active/passive filters; a linkwitz 24db @ 3khz + a passive line level xover for the bass?
Or do you guys think it would be wise to ignore all b&w's research and implement a (fairly standard) 3kHz / 300 Hz 3 way active linkwitz?
The number of amplifiers is not important, i've got 4 diy stereo amps laying around so...
Any hints/tips are welcome.
Si fractum non sit, noli id reficere!
Old 26th April 2004, 01:50 AM   #2
jackinnj's Avatar
Default build a pair of 24dB
op amps are cheap.
one thing to note -- when you cascade filters -- particularly in the Sallen Key topology -- component values become more critical. The TI filter tools allow you to input various precision grades of capacitors and resistors and look at the likelihood of the filter being on the mark.
you can also consider using an all-pass filter on the high or low to alter the phase --
Old 26th April 2004, 03:53 PM   #3
kingdaddy's Avatar
The Marchand XM-44 will do asymmetric slopes and anything else you want, a bit pricey though.
http://marchandelec.com/xm44.htm
Old 26th April 2004, 04:02 PM   #4
matjans's Avatar
omigod... that;s pretty expensive
just went out to get some components for a 24db @ 3000 hz / 12db @ 1000 Hz (second order in stead of a first order but still) and paid 28 euro's.
3 way linkwitz it will be !
Old 26th April 2004, 04:08 PM   #5
Bill Fitzpatrick's Avatar
Default Re: active corssover, 2 - 3 way or something else?
Assuming that you can get away with replacing the 24db @ 3K filter - which is unlikely since there may have been an adjustment of values for response tailoring or impedance accomodation- going up to 12db on the 1K filter is going to mess things up pretty well.
Old 26th April 2004, 04:27 PM   #6
matjans's Avatar
i completely agree with the second part. We'll see.
strange thing is the configuration of the xover. first woofer gets everything below 3000hz (no highpass), second woofer has an additional lowpass filter at 1khz.
If it doesn't work i'll just have to build a pair of speakers to match my crossover
Old 26th April 2004, 06:00 PM   #7
5th element's Avatar
Its not strange at all, that is a 2.5 way. The top woofer covering the whole range up to lowpass and then the 2nd woofer filling in for baffle step loss.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 26th April 2004, 06:58 PM   #8
matjans's Avatar
ah ok, didn't get that, obviously.
this, of course, also means that a 12 db filter is completely out of the question. 6db it will be then.
Old 26th April 2004, 09:46 PM   #9
Yup usually 1st order added on .5 speaker
Old 27th April 2004, 06:45 AM   #10
frugal-phile(tm)
planet10's Avatar
With 3 amps... amps on the bottom should be identical...
1 kHz for the 0.5 driver seems high (ie a baffle ~5" wide)... i'd set that one up so that you can play with it.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Active 3-ways with solen active loudspeaker module soundemon Multi-Way 14 19th March 2009 11:17 AM
Behringer DCX2496 I want to try active biamping using it as the active xover. georgehifi Digital Line Level 3 15th August 2006 07:46 AM
Active 3 Way vs Active 2.1: Too many alignments and too may questions. goldyrathore Multi-Way 1 22nd April 2005 02:42 PM
Looking at capacitors to tweak speaker corssover, need advise. Starlet Multi-Way 1 31st March 2003 02:36 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.13238 seconds (75.51% PHP - 24.49% MySQL) with 10 queries
