Old 26th April 2004, 01:52 AM   #11
Default Re: Maplins Close out on AP100Z0
Originally posted by pinkmouse
......and it may be the last chance you get to buy them with all the Audax nonsense....
What do you mean by that?
CM
Old 26th April 2004, 09:28 AM   #12
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Default Re: Re: Maplins Close out on AP100Z0
CM
They're stopping selling drivers for DIY use aren't they?
5th - thanks for keeping us updated on what you're doing, I look forward to hearing how you use them
Thanks for the WinISD numbers, I *would* look myself, but what with this laziness I'm suffering, in the pre-summer heat....
Old 26th April 2004, 10:05 AM   #13
Mark25 is offline Mark25  United Kingdom
Mark25's Avatar
does anybody recon this audax would be better than the visaton WS13E in my bargain basement 3 way active system. I've seen some positive reports about the visaton, it's only Euro16. The bass in my system will be the monacor sph-135c and the treble will be the audax TM025f1. any thoughts? assuming maplins are still stocking both by the time i get to ordering (asap)! sorry if i am threadjakking.
mark
Old 26th April 2004, 11:07 AM   #14
Mark25's Avatar
the link in my last post doesn't work very well, this WS13E link is more informative. BTW, thanks for the info pinkmouse, i was encoraged to see that maplin had added more tech info with their hi-fi drivers in the last catalogue.
Mark
Old 26th April 2004, 11:20 AM   #15
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
OK I cannot get 50hz f3 in a 9l ported box whatever tuning frequnecy I choose. The best I can get is 55. I am using 100% fill...
Hmm, I've just jumped on the wagon too. With a single driver in a 10l ported enclosure Unibox gives me an f3 of 45Hz! Max input of 3W and driver unloads below f3. SPL is 87.5db at f3 and ~90db from 55Hz upward. Used 'walls covered' stuffing parameter.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 26th April 2004, 12:10 PM   #16
SimontY's Avatar
So small and so cheap... I've ordered eight
My first DIY speakers use what I believe is the 8" version of this driver, so 4" at one fifth the cost...nice! The 8" has pretty crap bass, and needs a big box, but sounds pleasant enough, I expect a few of these working together will make nicer bass, as there will be more magnet per amount of cone being moved. And much less cone to flex per driver. Ok, I'lll shut up now, before I say something *really* stupid....
I'm thinking maybe 3 per speaker, all doing bass, but the bottom two rolled off from baffle width fr., for baffle step correction. That could sound nice and warm and smooth, I hope.
Old 26th April 2004, 12:15 PM   #17
SimontY's Avatar
Hmm, as they're so cheap, and need such small boxes, might it be a nice idea to load each driver slightly differenty, to get smoother bass?
For example, one sealed, two ported - each at a different tuning frequency. This could surely be used to make the speaker's bass a bit more 'exciting'.
Old 26th April 2004, 12:53 PM   #18
SimontY's Avatar
Ok, maybe 1 sealed in a diddy 5L section, and two ported sharing 16L, tuned to 54hz. And this could all sit in a very small floorstanding box of 14cm width, 25cm depth, and 70cm height (internal). Maybe a little taller and a tweeter would go in the right place.
Old 26th April 2004, 03:29 PM   #19
5th element's Avatar
Infact if you wanted you could do this as a three way, MTM or TMM mid/tweeter bit. Then MM on the bottom for the bass.
This way the top MTM/TMM would have the benafit of less bass so less excursion, and thus better midrange. You could also make the box best for mids and not consider bass, fully stuffing it with some good absorbant material.
The one problem I would see from wiring a MTM on top and then using two bass units to cover the baffle step so u'd have an MTM.5 way, is overall impedance, it would be really low if everything is parallel wired.
If you wired the MTM in series and the .5 MM in series then you would end up with about 6ohm impedance which would be fine. It sounds to me like you would want to use all the mid/bass to do the bass range because that way they would shift more air. Dont really matter theres a whole number of things you could do with them.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 26th April 2004, 03:49 PM   #20
SimontY's Avatar
Good input 5th,
You are right in thinking I'd want as many as possible working on the bass. I'm sort of thinking in terms of comparing these to my 6.5" drivers, and how loud they'll go in the bass, which is not staggeringly loud, but commendable. I think I'd need 6 per speaker to match my 2x6.5", so 3 or 4 would surely be reasonable... especially for a low-cost experiment speaker! And if I did go for 4 per speaker, it could still be a really petite cabinet, with a nice small footprint - easily sellable!
The impedance considerations did cross my mind, as did mtm.5!! We are thinking along the same lines, and I like the idea of having the midrange driver tailored more for good mids re. the stuffing. This is one other reason to mix sealed with ported I reckon - the sealed one would be the mid/bass, and could then be stuffed, whereas the ported would require no stuffing, or maybe just some nice carpet underlay on some walls...
I think with 4 drivers doing the bass the excursion would be quite small at normal listening levels, hopefully leaving the midrange nicely intact, and then at show-off levels the extra driver will help to pound the chest, lol, well, maaaaybe.
CD player Drawer open close open close open close qguy Digital Source 7 23rd November 2006 09:58 PM
WTB Audax AP100Z0 bhg41088 Swap Meet 4 28th October 2004 04:27 AM
Maplins close-out on Audax bass units Mark25 Multi-Way 15 28th June 2004 01:33 AM
Page generated in 0.11323 seconds (79.33% PHP - 20.67% MySQL) with 11 queries
