Old 25th April 2004, 06:01 AM   #1
RAW is offline RAW  Canada
Default SILK 4" out to 20k
My new design coming up.
A Tline using a 4" Vifa available in a ported design as well.
Pics from the Seattle DIY.
Measurments done against a Jordan X92 .
Both I built.The Jordans in a ported cabinet with Cherry veneer.
Silk used 1.125" thick solid Maghogany.
Click the image to open in full size. Click the image to open in full size.
What you all think.
Al
Old 25th April 2004, 06:48 AM   #2
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
I want to see a closer view of that response graph.
Old 25th April 2004, 06:49 AM   #3
drop me a email and i will send you the larger files
Al
Old 25th April 2004, 04:09 PM   #4
Brendon is offline Brendon  Canada
Hi Raw,
The Vifa has just over 1 mm xmax. I wonder what the full travel is like (?) - have you bottomed them out? I've thought about doing this very thing in the past (very attractive driver), but was concerned about driving them too hard. For say HT applications or general audio, versus say a PC application.
I've always thought that the anomaly in the response on Vifa's site at about 1.7 k was some sort of artifact of how they measured the driver. You often see it in other drivers. Your measurements show this to be the case.
How do you like the sound? The Jordan's a great driver. I think your Silk a cool idea. This driver in a TL could always be supplemented with a larger woofer. I'm sure that since this driver looks very easy going, this would be a chinch. Heck, you could probably put Silk on another woofer TL for the bottom end and cross around 300 to 500 or so...
How would you rate this driver against 3" and 4" Tang Bands for value?
Nice work!
Brendon
Old 25th April 2004, 05:02 PM   #5
Brendon
I have measured all the TB drivers to date and even have a few new ones to test in the next week .
Against the TB the only one I would compair it to is of coarse the W3-871S.
This Vifa with a poper filter on it controls the responce you see off the Vifa chart.
Smoother sound,clear,clean detailed.
This driver I first built in a small ported cabinet and had them at my last DIY in Nov .Well Mr Fullrange (Dave Dlugos) had never heard of them before at all.
He listened to them and once I turned around he had a screw driver in hand and had the driver in his hand writing down the driver number as well his friend that came over bought them to take back over to Victoria to do more with them. Like a TLINE
In general they have been played for about 4 hrs total ao far and very very surprized of the large sound coming out of this box.
The ported is very similar just not the depth.Of coarse you will get lower extention out of the Tline.
If driven hard with the tuniung in the Tline yes they bottom out.
But I mean hard.In the ported cabinet more forgiving as you tune them a lot easyer and I had the ported design done around 70hz with a HT you tuned them higher and use a similar filter.Click the image to open in full size.
Old 25th April 2004, 06:21 PM   #6
Al,
It is hard to tell about your graphs as the scale is very compressed. It would be great if you could change the vertical spacing of the graphs so that you would have a better chance of discerning the differences.
It appears that the Silk trends downward between 15 and 20 kHz by at least 5 dB from its midband level. The Jordan hangs in across the band but with higher perturbations in the treble area than the Silk. Conversely, the Silk is rougher in the lower mids than the Jordan. Can you hear any of these differences when you listen to them?
Jim
Old 25th April 2004, 06:21 PM   #7
Nappylady's Avatar
Please send higher-resolution response graphs to dr.napalm@attbi.com . Thanks. :-)
Old 25th April 2004, 06:34 PM   #8
Jim
I have only had them side by side for a few minutes as the Jordans went to Tim in Seattle after the meet for him to enjoy.
But in general even Bob was just stunned.The 4" was listened to against the Jordans at the DIY meet and a lot like the 4" over the Jordan for smoothness and detail but the low end went to the Jordan.
As well the Jordan, when Bob first listened to them here against the 4" Bob said the Jordan takes time to get more out of them.
Scaling yes I know .I just shoot all measurments on MLSSA and never mind playing with scaling as I only use it every other week and the settings have to be reset before each use.
All I am concerened with is the responce.
Just not enough time to get the SPL set up using MLSSA as well.
Between making cabinet and assembling cabinet I have no time at all.
Even yours I had hoped to get them out the door last week but the DIY meet I just had to many to do.
The new 4" from Bob I had to build a MTM with the new ribbon as well as veneer up those, the Jordan cabinets build and veneer them and last the Silks.Built them from scratch. out of 5" X20' blanks.
Then on to more HE 10 and HE 8 cabinets, sub cabinets.
Then Bob and Danny have ordered in a PILE of cabinets for Criterion and Diluceo's and I have to assemble 20 sets of crossovers,cut BH5 and fully assemble 20 set total.
I think I have a few days work
Still have time to set up MLSSA
Al
Old 27th April 2004, 01:43 AM   #9
Default Driver?
Is the Vifa one of the stock drivers or a proprietary model?
Perhaps the MG10MD09-8 as I queried on the full range driver forum?
Just curious...
Old 27th April 2004, 04:42 AM   #10
That is the modle but I have done a few things to it.
Not stock , has a filter.
Al
6.5" silver flute with 1 1/8" dayton silk dome tweeter jadenlinkletter Multi-Way 10 28th February 2006 07:20 AM
Dayton 1-1/8" Silk Dome Tweeter Dr. Photon Multi-Way 1 1st July 2005 08:41 AM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
FA/FS: Vifa Built 1" Silk Dome Tweeters CanuckAP Swap Meet 0 23rd November 2002 05:19 AM
Page generated in 0.12197 seconds (83.30% PHP - 16.70% MySQL) with 11 queries
