#2 |
Because his web site is so inscrutably difficult to navigate that you are the first to actually find a price list; no mere mortal has successfully ordered any products.
![]() Just kidding, of course (well, mostly); I've been curious myself. |
#3 |
hum, i clicked on this thread thinking they found a way to rip out a person's ear drum and make it into a speaker. no such luck. i would buy one in a second for the pure novelty factor!
#4 |
Why? I don't know, but I notice that they use inverted domes...
I suspect that concave dome tweeters are superior to ordinary convex dome tweeters simply by design. Because the dome is curved inwards, the voice coil can't (and shouldn't) be located on the very edge of the dome, but has to be smaller (as with cone speakers). This is beneficial to the performance of the tweeter because for the same size and the same dome material, the concave ones have a higher break-up frequency compared to convex domes. For example, a 25mm convex dome tweeter probably has a 25mm voice-coil, while a concave dome might have a 19mm vc. The vibrations that the voice-coils generate can be thought of as extremely fast ripples travelling across the surface of the dome. Therefore, in terms of break-up frequencies, the tweeter with the 19mm vc wins hands down because of the smaller distance that the "ripples" can travel before getting reflected and resonating. BTW. I was only talking about tweeters with hard domes like aluminium or ceramic or titanium etc. Many measurements show that soft dome tweeters (fabric, plastic etc.) sometimes have lower break-up frequencies than their accompanying midwoofers! CM |
#5 |
someone on the MAD board said they tested them and they weren't as flat as they thought they should be. I believe they are matched very well with the old EPI woofer and the two of them sum very nicely with a simple crossover. When used outside that system there may be some challenges to face. You might want to do a search at the MAD board or post there.
| Human Speakers | ryewoods | Multi-Way | 15 | 23rd September 2007 05:46 PM |
| Human Hearing................. | Gavinator68 | Everything Else | 25 | 26th January 2006 02:15 AM |
| Human Tweeters? | tmblack | Multi-Way | 14 | 28th April 2005 09:41 PM |
| human hearing | sss | Solid State | 123 | 8th September 2003 07:57 PM |
| human drivers | ucla88 | Multi-Way | 0 | 1st March 2002 03:49 PM |
| Page generated in 0.08751 seconds (70.10% PHP - 29.90% MySQL) with 10 queries |
