I posted last week and at that time I was looking at buiding the Vox 252 to be part of a second system I'm putting together. I subsequently had the opportunity to listen to the Vox 200 and decided on the spot to go with them instead.
I would be interested in hearing from any constructors of this speaker that may have tweaked or altered this design for better performance. I'll be retaining the same internal volume, however, I'll use 32mm mdf instead of 19mm. I'll brace the enclosure more substantially and I will not be recessing the bass driver as shown on the link below......I have no need to put a grill cloth over this driver. http://www.visaton.com/english/homehifi.htm (click on 3 way speakers) I'm aware they are fairly inefficient into a 4 ohm load, however, amplification is not a problem. Any additional construction tips would be welcome as I pick these drivers up this morning. Cheers,
It's true there is a fool born every minute; it's also true they don't die that fast. |
| Eagle users - help! | MikeHunt79 | Everything Else | 2 | 6th March 2008 05:09 AM |
| For FooBar users - | percy | Digital Source | 2 | 21st May 2005 01:16 PM |
| "Visaton - is it worth?" or... "Share your Visaton experience" | mr_push_pull | Multi-Way | 10 | 7th August 2004 06:18 PM |
| ESG1 users ? | jonk | Multi-Way | 0 | 2nd September 2003 04:56 AM |
| New LMS v4 users | Doug | Multi-Way | 2 | 16th December 2002 04:18 AM |
| Page generated in 0.06899 seconds (70.76% PHP - 29.24% MySQL) with 10 queries |
