Old 25th April 2004, 03:57 AM   #11
Very nice George, quite similar to some I made last year. What I was wondering is how did you manage to cut off the excess on the curved sides to make them flush with the front baffle? With somewhat limited resources I had a hell of a time because a curved side is very difficult to work with. I ended up using a lot of expensive filler in order to fill in my mistakes!!!
And I used 5 sheets of 3mm mdf laminated. It used LOTS of glue! But then my curved sides were the only external wall, they did not have the same internal construction as yours. But don't worry, you can't make the sides too thick, only too thin.
Old 25th April 2004, 11:30 PM   #12
Hi Akiwiskibum (just visiting or adding to our population?-I'm in Adelaide)
Sides will be flushed with careful use of a belt sander (variable speed) works a treat - did this on flushing up ends of internal carcase.
Hopefully only filler will be on screw holes and filling minor voids in laminations.
May use "nordsjo" filler instead of two pack car filler - but not sure yet .
BTW -the internal constrution was an attempt to cut down parallel sides
Good luck
george a
Old 27th April 2004, 08:25 AM   #13
Just passing through... well I've been in SYdney for the last 5 years nearly but intend to head back across the ditch later this year (if I can stop spending up of hifi bits!!)
Old 12th October 2004, 01:30 PM   #14
Hi All
just an update on the clonii fabers.
after many month of no movemnt they are back from the spray painters.
Finish is a fine metallic silver with a clear coat over.(spouse insisted on getting them done professionally!)
Next step is inserting baffle between front wings and formation of grille assembly (nylon cords of course)
Crossover space is in base of cabinet with leg/supports yet to be constructed
george a
Old 12th October 2004, 01:32 PM   #15
another view
baffle is not a baffle just a bord used for experimenting with finishes
george a
Old 15th November 2004, 12:07 PM   #16
Hi All
Just thought I'd post some additional views as the project has (slowly) progressed
the speakers are now functional and awaiting grilles (yes to be modelled on the Sonus type . I will use 2mm diam hat elastic for cords..)
Baffle fronts and top are covered in a vinyl leatherette which looks better in real life than in photos
Sides are not yet filled with sand and crossovers (while temporary an awaiting active versions) have been tweaked over last few weeks to get some agreeable sound out of them.
The XT25's are hard to work with and all tuning is by ear..
There are 2 sets of bnding posts on rear ( cheap knock-off's of WBT's i think) just below relex port.
images attached
george a
Old 15th November 2004, 12:11 PM   #17
another view
george a
Old 15th November 2004, 04:12 PM   #18
Jim85IROC's Avatar
Send a message via AIM to Jim85IROC
very nice!
Sonus Faber stradivari B4 Multi-Way 6 2nd August 2008 02:31 PM
Which midrange used in Sonus Faber rinx Multi-Way 27 20th June 2008 10:59 PM
Clonus faber george a Multi-Way 0 22nd April 2004 02:02 AM
Clonus Faber Crossover Seth Smith Multi-Way 22 22nd February 2004 04:48 PM
Copyright ©1999-2013 diyAudio
