Hi guys
This is a question for the speaker gurus on the forum. I want to modify a driver so that the Fs is reduced, but without radically altering it's sensitivity. It would be nice if the Qts goes up a bit as well. I want to use the driver in question on an open baffle, so VAS is not a factor at all. The driver specs is as follows: Resonant Frequency (fs) 40Hz Electromagnetic Q (Qes) 0.54 Mechanical Q (Qms) 6.56 Total Q (Qts) 0.49 Compliance Equivalent Volume (Vas) 293 liters Ideally I would like the Fs to go as low as 20Hz, but 25Hz will also be acceptable (but that is the upper limit). Qts must ideally be about 0.7, but as low as 0.6 or as high as 0.9 is still usable. I do have a professional speaker repairer\rebuilder that can help me with these mods, but I need to know what to do. Any ideas? Thanks, Deon
Reality is not digital, an on-off state, but analog. Terry Pratchett - Moving Pictures |
#2 |
Slice up the spider. :P
#3 |
I was wondering if loosening the suspension might do the trick. But how will that affect the rest of the parameters?
#4 |
Modifying the suspension would reduce Fs, but it would also reduce Qes, Qms and Qts.
Try a "Linkwitz transform" (pole-shifting circuit) if you want to use the driver you have. You can modify cutoff and Q independent of midband sensitivity..... Reducing Fs to 20Hz seems like it would not be especially useful in an open baffle speaker because it would be deep in the rolloff region anyway.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#5 |
Thanks Ron.
Deon
| Lower rails for lower impedance? | 95Honda | Solid State | 7 | 19th December 2007 08:59 AM |
| What Driver Is Best From 800Hz & Lower? | thetubeguy1954 | Multi-Way | 12 | 30th August 2007 06:09 PM |
| CDM-12 Modifying | poynton | Digital Source | 6 | 29th January 2007 07:26 AM |
| L-Lower? | oliverh | Pass Labs | 12 | 23rd August 2006 04:25 PM |
| how to lower the Fs of a driver | Puggie | Subwoofers | 15 | 3rd November 2005 10:54 PM |
| Page generated in 0.08922 seconds (68.92% PHP - 31.08% MySQL) with 10 queries |
