Truck bed liner tips
Old 21st April 2004, 03:59 AM   #1
moving_electron is offline moving_electron  United States
moving_electron's Avatar
Location: Where the rain does fall but the trees grow tall
Default Truck bed liner tips
I thought this needed to be a separate thread
Originally posted by tg3
Thanks to Al Wooley for the tips on getting my truck bed liner finish to look better, and thanks to everyone who helped organize the event.
So what were the tips and recommendations to get the nice finish on your Tumults?
Old 21st April 2004, 04:05 AM   #2
idex is offline idex  United States
Use flat black paint as a primer and sand smooth. Then apply the truckliner.
Old 21st April 2004, 04:20 AM   #3
Jye is offline Jye  Australia
Jye's Avatar
I have found that using a black primer is beneficial and then sand the primer back with 200 grit just enough to remove the brush strokes (if you have them) because they will show through.
It is still very important to have all of the glue joints on the MDF prepared well, otherwise they will still show up
Old 21st April 2004, 04:36 AM   #4
Jye's Avatar
I recently just used it on some AR bookshelfs
http://diyaudio.com/forums/showthrea...threadid=32344
Old 21st April 2004, 06:17 AM   #5
tg3 is offline tg3  United States
tg3's Avatar
Ok, here's what I've learned.
Prep your cab like you are going to do a piano fiinish. Don't count on the truck bed liner filling in any defects.
Use flat black paint for the primer. I used a mini (trim) roller with good effect. Multiple coats is better. Thin the paint just a bit, not too much. Sand between coats. Keep thinking about that piano finish.
The paint will tend to pool at the edges, which you must prevent.
It's not easy to get an even finish with spray on truck bed liner. Spray from about 2 - 3 feet. Use even strokes, start and stop the spray 'off the wood.' If you spray too much, the liner will pool and get shiny. Shiny is bad. Keep the angle and distance of the spray constant.
Al Wooley (RAW Acoustics) is a big fan of spray on truck liner (and gets very good results), but next project I'll prob try the roll on type.
HTH.
Folly befits a fool.
Old 21st April 2004, 06:30 AM   #6
tg3's Avatar
More tips.
The nozzle tends to get get clogged. Keep it cleared. Big drops will dribble down from the nozzle, so watch where you are walking.
Use an area with good ventilation! When I used my living room, we had to spend the night in the cellar until the upstairs cleared out.
Here is how my twin Tumults looked at the NorthWest Washington DIY meet. They need one or two more coats of liner, and a bit of touch up in the woofer recess.
HTH.
Old 22nd April 2004, 04:14 AM   #7
rotgg is offline rotgg  United States
here is a pic of mine there are no secrets we just sprayed the liner right on the mdf
Old 22nd April 2004, 04:56 AM   #8
tg3's Avatar
What brand did you use?
Old 22nd April 2004, 06:28 AM   #9
RAW is offline RAW  Canada
http://members.shaw.ca/awooley/pictures/1new4%23.JPG
http://members.shaw.ca/awooley/pictures/AV15.JPG
http://members.shaw.ca/awooley/pictures/FALA.JPG
http://members.shaw.ca/awooley/pictures/SuperELFHT.JPG
http://members.shaw.ca/awooley/pictures/TMWW.JPG
http://members.shaw.ca/awooley/pictures/craigssubs.JPG
Yes I have used it a little.
Ok NO big deal.
Fill all the edges and holes, sand smooth.
Paint with any roller.
I use cheap 3" rollers at the $1.00 store prime it with any cheap black paint.
I use Latex from WAL-Mart .
Dries fast and needs only 2 coats.
I can complete a sub finish from start to finished in 2hrs with spraying on the liner spray.
All this time really is dry time not hands on time.
As Thurman said to stand back about 2-3feet as the over spray is what you really have to control.
as well as the splatter from the thickness of the product.
Good luck
Al
Old 22nd April 2004, 01:42 PM   #10
brooklynrocks is offline brooklynrocks  United States
What's a good brand??? Al are those all the same brand of bed liner? all sprayed? Thanks.
Truck bed liner tipsHide this!Advertise here!
phase liner amp space2000 Solid State 17 14th May 2008 04:41 PM
What Box In My Truck? 26sonmytruck Subwoofers 1 15th May 2006 03:08 PM
Truck Bed Liner (UK) richie00boy Multi-Way 6 2nd November 2005 11:13 PM
Ute bed liner in Australia Jye Multi-Way 8 6th May 2004 02:07 AM
