Distance to Grill using a Peerless 12" XLS (830500) - diyAudio
Old 20th April 2004, 07:25 PM   #1
Question Distance to Grill using a Peerless 12" XLS (830500)
Subject: Mounting a 12" XLS with 10 mm foam grill. Look at the schematic drawing below!
GD = grill-distance
Proplem:
  • The driver can touch the grill if GD is to small.
  • For my design I would like to minimize GD
The linear xmax for the driver is 12 mm, but that is the excursion of the cone - not the rubber front of the driver, which I find not move as much as the cone.
I have tried to estimate the nessesery GD by playing 25 Hz in free air very loud - and I found that GD = 13 mm should be more than enough - can this be true?
Does anyone have experiences by the minimum of distance to the grill on an 12" XLS?
Ask
Old 20th April 2004, 10:53 PM   #2
Mudge is offline Mudge  United Kingdom
Set it to whatever you like, then mount the grill very loosely. If the grill falls off, you know you should be turning things down
Mark
The king of all that is evil has left the building
Old 21st April 2004, 07:22 AM   #3
67 Views and only one joke
Do all of you 12" XLS fellows really think that the driver is so good looking that you don't use a grill?
I think it's pretty to, but what about dust-damage?
And what about the design when you have grills on the tweeter and mid/wof - It would not be nice with only the XLS naked. (Just my opinion)
- Ask
Old 21st April 2004, 11:09 AM   #4
Sorry, I was being semi-serious. I would think that a 10mm gap between the top of the surround and the grill would be plenty, and if you do manage to knock the grill off, you probably are exceeding the useful operating range of the driver.
Mark
Old 21st April 2004, 12:43 PM   #5
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
I don't think you will get a definitive answer on this one (but maybe you will), so just experiment by running her at max and putting some cloth or the foam in front and slowly bring it closer to the sub until it just touches - then measure that distance.
Any particular reason you're using form and not the usual thin net type grill material? If I wanted the grill to be as close to the enclosure as possible then I would use thin material and inset the drivers.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 21st April 2004, 06:31 PM   #6
diyAudio Member RIP
Just note the top of the roll moves ~ 50% of cone excursion.
sreten.
Old 21st April 2004, 09:50 PM   #7
5th element's Avatar
I dont build grilles in any of my speakers. I like to see drive units my brother on the other hand thinks they are ugly.
Dust damage?? have not heard that one before. Now toddler damage thats real! I was a trogen of war for killing dustcaps in my youth.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
WTB Peerless 830500 12" XLS Bent Swap Meet 0 27th February 2008 03:52 PM
WTB: Peerless XLS 12" 830500 2pcs or Dayton 12HO Bent Swap Meet 3 4th January 2008 05:51 AM
Looking for a pair of Peerless XLS 830500 Miab Swap Meet 1 3rd January 2008 09:06 PM
WTB: 1 x Peerless 830500 12" XLS Bent Swap Meet 0 18th December 2007 01:50 AM
WTB: Peerless XLS 12" (830500) - just one StriatedFoot Swap Meet 3 22nd January 2007 07:05 PM
Copyright 1999-2017 diyAudio
